Newbie solar question
Stephen Clarke
Stephen Clarke
Tal y Coed, Wales
T6 Ocean 204 4Motion
Hello All
I installed Roger's system on my roof a couple of weeks ago, and it seems to be going really well. I've been able to leave the fridge on without the battery degrading. I keep checking the Victron app when it is sunny though, and noticed something odd today. Even though it was bright sunshine, with the roof up, and facing south, it was only showing 8w or so . Peak today had been around 80w (which is probably about right).
Is this normal? I have no idea!
DD0755AF-09A0-4E4A-8AF2-5EBD3213A952_1_201_a.jpeg20486EBA-8F27-4CE3-AFE2-2D4804018A2F_1_102_o.jpegtempImageZTKZgE.jpg
OK, thanks for the help. I thought it was showing solar power input, so regardless of the state of charge of the battery.
Solar panels only produce what is demanded of them, up to their capacity. I dont' fully understand it (well, I partially do, but won't make a fool of myself!), but that's how they work. So in full sun, when the batteries are full, the solar regulator doesn't get hot discharging 6 amps of solar power, instead, the panel just doesn't produce the power (and the panel does not get hotter instead as some rumours say!).
Think of them like batteries. A fully charged battery brimming with potential energy does nothing when nothing is connected to it, but when you do connect a load to it, the circuit is made and power flows. I think solar is similar, in as much as the regulator partially opens the circuit to the panel when the power is not needed
Perfect, makes a lot of sense Roger
Roger Donoghue
Roger Donoghue
TrevEC
T
Milly Molly
DGB99
DGB99
