Skewif
It’s not what you have, it's where you wake up.
Interesting point and you had me second guessing the rear springs upgrade for a bit there BUT... you do have to admit that the current set up on the 4M (mine anyway) is that they are sagging, admittedly its pretty level for it - as hard as this is to tell given the total lack of any real FLAT, no sloping areas in the outdoor real world. I stand by them sagging at the rear too much as the camber on the wheels is more than I believe it really should be - I'm concerned about tire scrub its so bad. Your optical illusion suggestion is really interesting tho and I do worry that you are correct and we are chasing a non issue.
Anyway - to answer your earlier Q Skewif, I'll get a full report on here this week - in to get the springs done tomorrow. As for driving performance - I'm not really one for looking to get sports car performance out a van so its hard to say. My main concern on a vehicle is performance in rough conditions (and currently - how warm can the seat go, how good is the stereo and how timing the pre-heater before I brave the cold run out to the van this winter here in the North!!) It drives fine really having had pickups before this one. Not changing the dampers yet but will consider. I have both F&R T32 springs (cotrim.co.uk) here and would consider picking up the front if needed.
Great info as always on here. Thanks
Sorry if for a moment you were having doubts but I was choosing my words very carefully in the hope they would not have that effect. According to VW the 4 grey rough road spring should add 20mm hence why I was talking greater lifts.
I'm totally with you and would be doing the same if I had your van. 20mm may not sound a lot but visually it can have quite an impact. I look forward to hearing how you find them.
Re the stereo, I found the low bass really lacking in the std front speaker setup so followed advice on another forum and lined the inside of the door and door card around the speakers with sound deadening sheets. Very noticeable improvement in the lower bass and gets rid of the irritating resonance in the upper base. A very worthwhile cheap mod if you like music with a bass line.
