Stuart
- Messages
- 613
- Vehicle
- T6 Beach 150
Oh go on! It really would be interestingNot much point as I have a T5.1 not a T6.
Why?Oh go on! It really would be interesting
Why?
@WelshGas thanks for the photos but it's the VW info from the handbook / sales literature that I'm keen to see
This is the best I can find - you'll have to sort out which dimensions are of relevance.I guess the 186 / 569 kind of does, as it should be possible to get from that to the usual wheel centre to arch measurement
Measurements
Centre of wheel to high point wheel arch FRONT 43cm REAR 42cm
Side Cill from Bottom of cill to floor FRONT 26 cm REAR 26 cm
Fully loaded, as we are going away, 80L Fuel and 30L water.
Sort of confirms that the sagging rear is just an optical illusion, I would be interested to see your measurements to top of rear bumper & bottom of front to see if they match the VW diagrams.
https://bb-database.com/jctumbau/web/international/transporter-technische-zeichnungen
Just be aware if it is stiffened up for towing then it could become uncomfortable when not.Mine looks much the same, It has been bounced all over rough roads, even taken flying on one occasion, is in use all year round, all types of terrain and this afternoon was towing a caravan, all fairly effortlessly so I am quite happy with it although towing it did resemble one of the ships I was on in a force 10 when going over bumps so may take advice whether stiffening the rear any further would help.
Oh, and don't ask me to get on my knees to look at the springs as I would need someone to point them out to me![]()
Airbag inserts for the springs maybe a good alternative. Pressurised for towing and depressurise when not.
http://air-lift.co.uk/61-universal-air-helper-kits
Your knees are halfway between your feet and your hips.
(I'll get my coat)
Mine is 40cm front and rear. T5.1 lowered 30mm.Measurements
That bodybuilder website is a mine of information!
In case it's of any use to anyone, I took some measurements of the T6 Window Van from the DXF drawings with AutoCAD:
Front wheel centre to wheel arch - 410 mm, centre to ground - 339 mm.
Rear wheel centre to wheel arch - 389 mm, centre to ground - 312 mm.
The drawing shows the ground level - "Roadway plane with vehicle loaded", as a horizontal line, but the rear wheel of the van is compressed more than the front. In the drawing, the centre of the front axle is 24 mm higher than the rear. At the same time, the sills are horizontal - parallel with the roadway plane.
The gap between the top of the front wheel and the wheel arch is 61 mm, the gap at the rear is 39 mm.
It seems like there is more space at the front compared to the rear, by design. Obviously this can be varied with different vehicle loads and springs.
There is one other measurement I've never been able to find - the distance between folded mirrors. On the drawing this is shown as 2093 mm. The distance between door handles is 1904 mm and mirrors unfolded is 2230 mm.
