Anthony1
Too young to be old
- Messages
- 1,287
- Vehicle
- T5 SE 180
A little more information would be helpful.I have a power bank for jump starting vehicles. It works for my son's Toyota Soarer 2.5ltr straight six and my other son's BMW 325i, ie another straight six - both petrol.
But it will not jump my 2ltr, auto Cali.
Any ideas why not?
Thanking you in advance.
The thicker the jump leads the better
And you have the Glow Plugs to power up, especially at this time of year.A diesel engine has a higher compression ratio than petrol and so when starting the starter motor pulls a larger current from the battery in order to turn the engine over. Hence the bigger engine battery.
That power pack cannot supply enough current to turn over your Cali engine but will turn over an equivalent petrol engine.
Alan
The cheaper ones are JUST the case.the cheaper one comes with a hard case.
The £17 one is just the hard case.Thank you everyone for your comments and info. I have ordered the one Westfalia and others have.
Ebay prices for the exact same item, range from £17.31 - £90.95. Unless I have read it incorrectly. And the cheaper one comes with a hard case.
You’re probably right on the limit of the battery’s life. My OEM battery on my 2011 T5.1 140PS kept discharging and no amount of recharging would bring it back.Sorry.
I have a 2012, T5 (Facelift, I think). SE TDI 180 4x4 Auto
I checked the connection and it barely turned over
I have since jumped it from my other car, it is now on charge and we will go out for a run tomorrow.
Maybe I need the one mentioned above, ie more power.
Thank you
I connected my Noco to + and - on the battery = no problem.I know this is an old thread, but I don't want to start a new one. Where does one connect the earth lead when charging or using a jump starter? I know that it shouldn't be to the battery earth but the leads on both my charger and starter are not long enough to reach the engine block and I can't find an earthing point, (other than the bolt for the battery clamp), close enough. 2018 T6 Ocean.
What is likely to happen if the battery earth is used with a Noco starter? And how can it be fixed?
The instructions on my pack say to use the -ve terminal too. TBH the leads are so short, there is little alternative.I know this is an old thread, but I don't want to start a new one. Where does one connect the earth lead when charging or using a jump starter? I know that it shouldn't be to the battery earth but the leads on both my charger and starter are not long enough to reach the engine block and I can't find an earthing point, (other than the bolt for the battery clamp), close enough. 2018 T6 Ocean.
