beardie
- Messages
- 343
All engines are mass produced items with hundreds of component parts. Each part has its own variations in size and fit. VW will have tested many individual parts and completed engines. Their aim will be to reduce failures of parts and engines to a certain (very small level) that's consistent with acceptable performance. Some parts will fail (fact of life) in a standard configuration. If an engine is tuned the set of assumptions is shifted. It's likely over a large enough sample that extra power / torque will cause a higher failure rate.
Doesn't mean your engine will fail, but it's probably more likely to over an extended period. Perhaps by only a couple of percent. I don't think any one tuner will have a large enough sample in controlled conditions to know the impact of their changes.
If I was to tune an engine I would be inclined to change oil more often and otherwise try and look after it to counteract the effect of the additional load put on it.
