spiderstu
- Messages
- 26
I have a bit of a puzzle and hoping someone out there has the solution.
I have removed our side awning. I'm struggling to remove the front side awning bracket from the van. The bolt hole mounting point at the rear is preventing me from sliding the bracket off the rail, and the same is true at the front of the Cali too. (the rear bracket slid off no problems).
Video below shows the issue.
The bolt that holds the awning in the rail appears to be non-removable, the rear square nut is fused to the bolt, so I can't loosen or remove it. The more I tilt the bracket to get it to clear the mounting point, it tightens it in the rail.
Would be very grateful for any advice from the wise.
