jts46
I was always told when I worked at auto electricians to disconnect negative first, when installing new battery connect positive first
You should research if both your leisures need replacing (assuming it's an SE / Ocean .Hi. Can someone recommend a good leisure battery for a T5 that goes under the drivers seat please
Which vehicle?Hi. Can someone recommend a good leisure battery for a T5 that goes under the drivers seat please
Which vehicle?
On the California the Leisure Battery is fitted under the Passenger Seat and normally 75 to 80 amps.It’s a friends vehicle which is a T5 conversion.
Your friend really needs to examine his battery then, check the name and model number, Amps and measure height, length and width. Height with and without connections.He said his is under the drivers seat
Type: Start/Stop AGM AH Value: 80Ah CCA - Start Up Power: 800 Dimensions (LxDxH): 317x175x190mm Guarantee: 4 Years Guarantee Period: 4 Years
