Roof bed lights …
P
Persephone
Cumbria
T6.1 Ocean 199 4Motion
T6.1. I’m sure it’s us - but the lights in the roof bed work fine, and then they don’t, and then they work just fine the next day … is there a setting we have missed ??
newboldi
newboldi
Leeds, UK
T6.1 Ocean 150
Not sure if this helps…but if the roof isn’t 100% up, they won’t work. Mine developed a fault that the roof would drop a cm or 2 and they wouldn’t work until it was opened again fully…
P
Persephone
Cumbria
That’s really helpful - I’m just looking at a similar thread where the roof isn’t playing nicely - I will see what re-opening does. How did you get a resolve ? Or didn’t you really ??
newboldi
newboldi
Leeds, UK
T6.1 Ocean 150
Well…it’s only a recent thing. The dealer says they have made an adjustment to fix it otherwise it’s a bigger job to replace some struts that pop the roof up??? Let’s see
GP
GP
Bath
T6.1 Ocean 199
I'd be interested to know if the 'fix' has worked and if so which dealer did it. Our roof is sinking quite a bit and therefore the lights also don't work and it is booked in to VW Bristol in October to see if it can be repaired. VW Assist thinks it is an hydraulic issue so be good to know what your dealer did to try and resolve the issue?
andyinluton
andyinluton
T6.1 Ocean 199
1st repair is upload latest software, this doesn't stop the roof sagging but does sort the control panel so that the roof isn't stuck anymore, it lets you put the roof down even if it has sagged to the intermediate position. Its not really a fix, more a bodge to stop the likes of me ringing VW assist every morning to put the roof down as a subtle hint.
2nd repair is replace the hydraulic rams, takes an hour or two & I've yet to hear from anyone who has had this repair done & its worked!
3rd repair is replace the hydraulic pump, it is believed that there's a batch out there that have faulty valves, from what I've seen this is the 19 this affects the early T6.1s its major job & the garage wants 4 or 5 days. Mines being done in a couple of weeks, I'll update on this forum if it fixes it.
GP
GP
Bath
T6.1 Ocean 199
I have just been told by a dealer that there is a new VW bulletin that has been issued to dealers on this problem and no doubt it follows your experience. Let's hope we can all get the required fix and no more collapsing roofs in the night! Look forward to hearing the results of your work in a few weeks' time - mine also goes in in three weeks' time.
GP
GP
Bath
T6.1 Ocean 199
I'd be interested in knowing which dealer you are dealing with. Have they done steps 1 & 2 and now booked in to do step 3? I do not have much faith in my dealer and the one I bought it from (which I do have faith in) is the other side of the country.
andyinluton
andyinluton
T6.1 Ocean 199
Dealer is Woburn Green, and yes we have done steps one and two. Three has been delayed for a couple of months waiting for a pump to turn up. Now the pumps here it’s another 3 week wait for a slot when a courtesy vehicle is available. They want the van for a week to do the replacement.
GP
GP
Bath
T6.1 Ocean 199
That's interesting. I have just spoken to my dealer and they have said that VW technical bulletin says it is not permitted to replace the hydraulic pump. They are going to do the technical fix per the bulletin (ref 2010030/7). Be good to touch base with each other in a few weeks' time. best of luck!
andyinluton
andyinluton
T6.1 Ocean 199
As the pump is the only bit of the system that now hasn’t been replaced they don’t really have a lot of choice.
I wonder if they really mean do steps 1&2 first and 3 only as a last resort.
Up until last week there were no pumps available which may have had an influence as to the approach.
If it was out of warranty I would be doing the fix myself, chances are it’s a bit of swarf stuck in a valve so it’s not sealing properly.
GP
GP
Bath
T6.1 Ocean 199
Think you might be right. Lets see how they both get on.....
andyinluton
andyinluton
T6.1 Ocean 199
Have you actually seen a copy off the bulletin ? I would be interested to see it.
GP
GP
Bath
T6.1 Ocean 199
No I'm not allowed to, I asked for a copy but they said it is confidential. But two different dealers (the dealer I bought the van from and the dealer it is now booked in to do the work) have read it out to me so it does exist and is in circulation for the dealers to read and action. They even read out the bit that said the pump should not be replaced.
