California4x4
I’m on a trip to Europe and will be carrying mountain bike, snowboarding gear, surfboard and more. I will be working on the road and prefer to wild camp, so I also need some solar.
I modified the roof box to allow the single 120W pannel to be removed from the roof rails and mounted to the box without modification. I put an extension in to lengthen the cable.
It is possible to mount the roof box and the surfboard side by side (just). However I found the weight of the box when loaded is all over one side of the roof. I didn’t want this to cause the roof to malfunction with the uneven load. So I needed to centre the roof box and find a way to mount the board on its edge.
This is the solution, 2 x steel fabricated brackets that allow the board to slide between them and then a bungee to secure the board for short trips to the beach. For travel, there are 2 Thule steel core lockable straps that both wrap twice around the board and the roof bars.
End result is 2.6m tall with the board and 2.4m with only the box. The board can be stowed inside when getting on a ferry etc if there is a height issue.
