roof drains blocked
If yr actually asking P, just had to unblock mine, Rob at camper sales in Burgess Hill sorted it for me, used a flexible tie wrap to make sure the down pipe was not dislodged, then the high pressure airline, took 10 mins max
Many thanks Mick
Personally, I would clear it with a cable tie and not use a "High pressure" airline as you risk blowing the pipe off the inside.
I agree with syrhttps://vwcaliforniaclub.com/members/vwsween.18946/inge method, used it last week. Force some water in then suck it back out. repeat a few times but exchange any dirty water full if bits with fresh as you go. When it moves easily pour water into the channel and you may hear the gurgle of a clear drain quickly followed by water under your wheelarch.
You are welcome.
I used to poke around in the holes and managed to undo the connection, so all the water went inside.
Billywizz
Jabberwocky
Jabberwocky
T
9K
californiaT5
californiaT5
Ting Tong
Jabberwocky
Jabberwocky
Steeble
Lambeth Cali
Lambeth Cali
