soulstyledevon
Kennycalifornia
- Messages
- 6,517
- Vehicle
- Cali now sold
The problem here is some suspension shops are telling people that on a California if the floor is level and the rear arch gap is lower as designed, the suspension is wrong and negatively affects steering, and then sell these trusting clients rear spring spacers which leave the rear jacked up in the air. This gives a higher center of gravity at the rear of a heavy vehicle, which is the last thing any shop should be promoting.
To put it clearly, if the floor of the van is level, the rear arch gap will be lower than the front gap. If the front and rear gaps are equal, the rear of the van will be 40-50mm higher than the front. This is normal on an empty Transporter, which will come down when loaded, but not on a van loaded with California equipment, which should be level for handling reasons as well as bed and kitchen configurations.
100% correct.
