Shower expansion chamber. Any ideas
CYCLOPATH
CYCLOPATH
Blackdown hills, Somerset
T5 SE 180
I have a problem. We mostly camp off grid, and have used a home made solar shower very successfully.
It’s just a black drain pipe attached to the other awning rail..BUT
It gets very hot, and expands and contracts, as it does when we go up and down mountains. This breaks my seals on the joins. I’ve mended it many many many times. Our last we month trip , to Greece and back, we just accepted a drip. The shower still worked.
I’ve tried all sorts of glues, but the best result so far has been a cycle inner tube screwed in the top.
I’m rebuilding it again now and wondered if anyone has any better idea.1754827252105.jpegin the pic you can see the inner tube on top, and my multiple repaires.
I’m rebuilding it again now and wondered if anyone has any better idea.View attachment 139474in the pic you can see the inner tube on top, and my multiple repaires.
I would have thought you would need some sort of pressure relief valve. If the joints are too strong then the drain pipe will give instead.
Nice idea! As Welshgas suggests you'll need to install a pressure relief valve, you can pick one up for around £10.
I’ve gone a different way, I have installed a privacy room to the same passenger side awning rail and use a foot pump operated shower bag. I do like that your system heats the water in hot weather so it’s ready to go.
It’s mostly for storage. Off grid, water is a limiting factor, especially as we like to shower daily. It holds and extra 15 litres. We do decant it into a pump up shower at times. Travelling for months, we can’t carry too much water inside the van
I have a Lifesaver for extended trips which holds up to 20lites although I usually carry it empty. It has a shower attachment but the pressure is probably less than you get from the VW built in shower/pump. It can be filled from rivers/lakes - more or less any water source and make it safe for drinking so perfectly fine for showers. Not as easy to store as your set up though, I store mine on the roof which is fine when it’s empty, wouldn’t work full!
