L
Leopold_Stuff
Hi, what is your suggestion regarding cable diameter for 2 panels 100W each? Everywhere I see 4mm but it seems to be quite thick. Isn't 2,5 enough?
What about UV/weather protection? Is that necessary? I'm trying to find a curly cable that fulfill those requirements but without any success.
How do you connect 2 panels? Parallel or in series? I found that parallel system is more efficient when one of the panels is in the shade but on the other hand connection in series gives you more V, so in the lower light it keeps charging the battery. What is you opinion?
