couplands
To be fair, I have a tow bar and stated that on the order. Am I meant to fit the spacers when I have a tow bar ….?You have the short towbar version give the shop a call they will send you the correct one
As I said, I’m using the highest holes. If I use the other holes it would be even looser.The end of the cradle nearest the front of the van is held by a pin that passes through a couple of holes. There are a couple of sets of holes to allow for different tyre widths. It sounds like you need to adjust yours.
That’s good hear, any idea on part numbers and/or links to purchase…?There are different size spacer for 16inch or 17 inch wheels
Great, see you tomorrow…;-)i will talk to you tomorrow about it at the shop
Thanks for your help guys and gals. Great service.yes pop into the shop and we will look for you
HiThanks for your help guys and gals. Great service.
You might also want to double check that an R16 rim will clear the brake calipers if your profile is correct and you have an Ocean - from memory, the front calipers on an Ocean require a 17" rim.Another question, I bought a spare wheel/tyre that is 205/65 x R16. I fitted the spare wheel carrier with the supplied spacers and bolts (I left off the Sparesafe for now) and fitted the spare wheel. But it wobbles in the carrier as the carrier doesn’t clamp it fully to the underside of the van. I used the higher of the two locating holes on the front of the carrier.
Does a 205 tyre not work with the carrier..? The wheel/tyre was a new take off from a T6.1 Transporter.
That's a good point, never thought of that...! Thanks for the heads up...You might also want to double check that an R16 rim will clear the brake calipers if your profile is correct and you have an Ocean - from memory, the front calipers on an Ocean require a 17" rim.
I went back to the club shop and got the normal longer bolt and a shorter spacer and it was just right.Hi
Did you get to the bottom of the sparesafe length of bolts for a Cali with towbar (t6.1).
I seem to be going in circles trying to find the answer.
Phil
Do you by chance remember what length bolt kit you ordered?I’ve got a tow bar and just ordered the spare safe from the club shop and it fitted fine
They only come in one size?Do you by chance remember what length bolt kit you ordered?
They used to sell two versions, the std one and one for fitting with a tow bar (which I bought). It turned out it didn't fit with the tow bar and the std one was fine. Even the guys in the shop didn't understand what the purpose of the "tow bar" version was.They only come in one size?
SpareSafe – T5 T6 & T6.1 Spare Wheel lock (inc Security Bolt)
The Sparesafe locking system will deter even the most determined thief for stealing your spare wheel. Specailly designed for VW T5/T6 & T6.1.vwcaliforniaclub.com
We ordered this and with a 17" wheel in a hanger kit all works perfectly.
