charlie16161
I dont actually use the van sat nav as its well out of date. I use google maps on android auto and bluetooth to the car audio. So I guess i could disconnect this? Assume it will plug into the head unitIt is.
I'll try again later. Its a small 7.5 amp in the middle row. I did check all the fuses but its worth double checking thanks.According to @sidepod wiring diagram there are 2 fused supplies to the switch SB12 and SB22.
What happens if you remove SB22 but not SB12?
Yes. Should plug into the back.I dont actually use the van sat nav as its well out of date. I use google maps on android auto and bluetooth to the car audio. So I guess i could disconnect this? Assume it will plug into the head unit
Just to clarify I removed the switch by pushing it in on off then turning to dipped and pulling the switch unit out. I then uncoupled the electical connector and retested the drawI assumed if Charlie removed the switch he would've removed connector T10 which also includes the SB22 feed?
