Brayveheart
Hi
I've been running a 2006 California 2.5 tdi Auto for a few years. It developed an issue a few months back whereby it wouldn't start. Keys in, turn ignition and nothing turning. I moved the gear lever down and up and tried again and bingo ! It starts. I lived with that issue for a few months and, as it only happened occasionally, I planned to get it looked at properly at next service.
A few days ago the issue became more serious. It wouldn't start at all. The recovery company (AA in this case) came out and, after I explained what symptoms I had seen, the guy wired power directly to the starter motor and it started 1st time. When he tested it with a meter, he confirmed that no power was being sent to the starter when the key was turned. I drove home and now it's in the driveway awaiting an enduring fix. I'm hoping for some help on this and, though I've read other posts that sound similar in terms of symptoms and fix, there are some key bits of information missing.
Questions:
From my description, does it sound likely that the "inhibitor switch" is the issue here?
I've also seen reference to "Transmission Range Sensors"; could that also be a source of the problem?
If it isn't either of these, what else does it sound like it could it be (other than a wiring issue) ?
On a 2006 2.5TDI 174 Auto box, where is the inhibitor switch? Is it on/underneath the gear shift/lever assembly itself (accessible from inside the cabin) or somewhere else?
On a 2006 2.5TDI 174 Auto box, where is the Transmission Range Sensor ? Is it on/underneath the gear shift/lever assembly itself (accessible from inside the cabin) or somewhere else?
Does anyone have any VW part number for these parts? Inhibitor switch and Transmission Range Sensor?
Can anyone point me at a picture of what these things looks like?
Some background:
Battery has been checked and is fine
Immobiliser has been checked and is fine
VAN had a new starter fitted in last 12 months
Thanks for your help ! Desperate to get the van back on the road
Questions:
Some background:
