Ladymuck
Yes I've done that a few timesCan you switch Off the Control Panel and switch On as you can on the T5/6?
So glad that it hasn't spoilt your trip away. Keep us all updated. These gremlins are bound to visit us all at some stage, I'm guessing.Hi everyone, so after 2 nights off the grid the battery is working fine ! The fridge was on, using lights & charging stuff. The battery low warning sign is still on and it even came up on the driver dashboard as well (said the second leisure battery was low) Now the water pump is flashing as empty despite filling it up recently. I think there must be a control panel problem, I have to say I am relieved it's not the battery as at least I can still do my trips and get it sorted in the winter.
Here's the CP this morning:
It's not good on a vehicle that's not even 6 months old, but it could be worse !So glad that it hasn't spoilt your trip away. Keep us all updated. These gremlins are bound to visit us all at some stage, I'm guessing.
Control panel complaining that second battery is low is indicative of something like this:
https://vwcaliforniaclub.com/threads/2nd-battery-not-charging-t6-1-coast.41152/post-533839
I've linked to post 25. The outcome was good for @Ferryman not so good for @Coasterman. Perhaps their experience will be useful to you.
@Coasterman @Ferryman did the battery actually not work on your vans ?Thank you Yosserman, I'm not technically minded enough to do those suggested in the post you linked to. Not sure if the issues are the same ? My water pump is also flashing an empty warning now.
My van was running on 1 battery as the fuse on the second was blown probably since delivery. I suspected this as was only getting couple of days life with fridge on. Only way to confirm for sure I think is to get into the rear battery and put a meter across it should read same as front battery. Unfortunately this means removing the lounge bed that is awkward and heavy otherwise easy to check.@Coasterman @Ferryman did the battery actually not work on your vans ?
Removing the lounge bed is a 2 person job really otherwise you risk damaging your internal trim.My van was running on 1 battery as the fuse on the second was blown probably since delivery. I suspected this as was only getting couple of days life with fridge on. Only way to confirm for sure I think is to get into the rear battery and put a meter across it should read same as front battery. Unfortunately this means removing the lounge bed that is awkward and heavy otherwise easy to check.
Ah ok, I 'think' the problem with mine is different (although I'm no expert), the batteries themselves appear so far to be ok, flashing as low on the control panel but fine in practise after 2 days off grid. An additional problem is the water tank saying empty when I have filled it. I think it must be a control panel issue rather than the batteries themselves.My van was running on 1 battery as the fuse on the second was blown probably since delivery. I suspected this as was only getting couple of days life with fridge on. Only way to confirm for sure I think is to get into the rear battery and put a meter across it should read same as front battery. Unfortunately this means removing the lounge bed that is awkward and heavy otherwise easy to check.
That's not happening here, I wish I was more hands on with the van, but I'm not and I guess that's why I went with a new one ...Removing the lounge bed is a 2 person job really otherwise you risk damaging your internal trim.
Anyone know what the red triangle in the fresh water tank indicates (sensor fault)? Empty is just empty, not red triangleAh ok, I 'think' the problem with mine is different (although I'm no expert), the batteries themselves appear so far to be ok, flashing as low on the control panel but fine in practise after 2 days off grid. An additional problem is the water tank saying empty when I have filled it. I think it must be a control panel issue rather than the batteries themselves.
