Jimcrow
- Messages
- 7
hi, I've had the red plastic cover for the tailgate brake light disappear this weekend. Could anyone tell me what the part no. is and if it just simply pops on - I'm assuming it does. Thanks.
Hi, do you still have these available at £35.88 with 20% off? Our red reflector cover seems to have popped off as well. How would this be re-fitted/attached please? Thanks,Hi.......
They retail at £35.88 for the whole LED unit. If you order from me I will give 20% off plus postage.
Cheers
These were subject to a recall, do you know if yours was ever changed? if not you should be able to get it done for free.Hi, do you still have these available at £35.88 with 20% off? Our red reflector cover seems to have popped off as well. How would this be re-fitted/attached please? Thanks,
Hi @andyinluton no it was never changed and wasn't aware of any recall ? :-( Do you know what the procedure is for this? Shall I call VW to discuss further? Is there a link on the forum to any recall discussions?These were subject to a recall, do you know if yours was ever changed? if not you should be able to get it done for free.
I also have a T5 SE. When I took my vehicle back to the VW dealer for a service they told me that the vehicle had a recall on it and replaced the unit while being serviced for free. It was still under warranty anyway.Hi @andyinluton no it was never changed and wasn't aware of any recall ? :-( Do you know what the procedure is for this? Shall I call VW to discuss further? Is there a link on the forum to any recall discussions?
Many thanks for this.
@andyinluton apparently it is down to specific chassis numbers, anyone else found this to be the case?These were subject to a recall, do you know if yours was ever changed? if not you should be able to get it done for free.
@andyinluton okay thank you. Can't be done with yet another argument with VW on what should or shouldn't be done and going around various dealers having different responses, I've luckily a mechanic ordering me one and replacing it for me, thank you all for your advice. Keep on trucking......Ive just come across the service receipt for when my brake light was done , its campaign 94I9 s-high level brake light.
