Well I haven't driven the vehicle since I completed the fit and set up. I've been waiting for the replacement upper rear brake light to arrive. I fitted that today after postie eventually arrived. The poor chap looked rather exhausted nearing the end of his busy Christmas round.So...Now you’ve got the nextbase all installed nicely...what do you think of it? Any good?
Anyway, what are my first impressions of the Nextbase GW522 dash cam and rear camera?
Firstly, I've had Nextbase dash cams in our previous two Calis and we also have another in my wife's car. However they were all the previous generation model which I found rather fiddly and not that easy to navigate. The GW522 is much much better. It has a 3" touch screen with excellent instructions to guide you through the step by step set up instructions. All the functions are carried out via the bright clear touch screen. This makes a pleasant change as the previous model has un-illuminated buttons which you can't see at night. The instructions are very simple and easy to both use and understand. I hate this sort of techy stuff so anything that is simple to operate well gets my seal of approval.
It comes with lots if useful features such as a touch screen camera for taking stills. The video quality is excellent. Rather than me trying to explain all of these features it might be better to check out the many video reviews online. It is supposed to be one of the best dash cams on the market at the moment. It has Bluetooth, wifi, Alexa and even an SOS feature which will automatically contact the ambulance service with all your particulars should you be unresponsive after an accident. You have to load an app onto your mobile to use these though. I probably won't use these functions straight away as I don't really do mobiles and Mrs Bs mobile is currently choked up with all sorts "usefull" info. I might have to get her an upgrade!
The only negative that I have discovered to date is the design of the rear camera. However, I have already mentioned that issue so I won't repeat myself.
I bought mine several months ago from Halfords when they were on a special.Glad you’ve got the light sorted.
You look to have done a really tidy install.
Must say I’m tempted by one myself especially since they are on sale again in Halfords, seems a lot of camera for the money.
Must try and resist lol
Thinkware Loz ? I’ve got the same setup . Works well .Here is where I meant
? Start again’t Borris ? How many hours did it take in the end Borris ?Here is where I meant
I'm about to fit a Brake light with Reversing Camera to a 2013 Beach. I think I've got my head around the upper rear door panel, but was wondering if you had any tips for routing the cable along the near side of the van?
Near side is the easiest as there is sufficient gap behind the cupboards/kitchen. Just ensure that you zip tie the wires to existing wires or to any place along where you are able to.
Beyond the kitchen, you will find existing wiring going to under the passenger seat and other places. Follow that.
Unfortunately don't have any pics, but I am sure someone will come along with some detailed pics.
When people fit solar they route the wire along the bottom on the trim panel below the window and into the Jack storage area. Apparently you can push the cable into the gap between panel and flooringThanks Kurienp,
it's a Beach, so in some respect it may be easier.
I had thought that going along the window top panel would be best, but I can see that you are right.
Much appreciated.
Down to the floor, at the rear, and then using a trim tool you should be able to push the wire under the trim on the Nearside to the rear of the front passenger . Under the carpet in the cabin and up into the Dashboard.I'm about to fit a Brake light with Reversing Camera to a 2013 Beach. I think I've got my head around the upper rear door panel, but was wondering if you had any tips for routing the cable along the near side of the van?
hope that’s helps
Thank you.When people fit solar they route the wire along the bottom on the trim panel below the window and into the Jack storage area. Apparently you can push the cable into the gap between panel and flooring
hope that’s helps
I should have said it's the 4 seater Beach, but the principle is the same.Down to the floor, at the rear, and then using a trim tool you should be able to push the wire under the trim on the Nearside to the rear of the front passenger . Under the carpet in the cabin and up into the Dashboard.
If you search @Roger Donoghue he has some posts showing the routing of the solar wiring which should give you some ideas or search generally for fitting solarI should have said it's the 4 seater Beach, but the principle is the same.
That's great thanks. Not sounding like a 3 day job now.
Thanks Kurienp,
Much appreciated.
I'll look now. Thanks.If you search @Roger Donoghue he has some posts showing the routing of the solar wiring which should give you some ideas or search generally for fitting solar
Thread attached to my post #67 ( save you searching) “removable drill free solar”I'll look now. Thanks.
That's Perfect Perfectos, exactly what I needed to see and read.Thread attached to my post #67 ( save you searching) “removable drill free solar”
just click on the thread images to open it up
Post some pics of your process and fitting to assist othersThat's Perfect Perfectos, exactly what I needed to see and read.
Brilliant.
I'll give it a try.Post some pics of your process and fitting to assist others![]()
I fitted a rear window cam to our 2019 Beach some months ago. There's a brief description of the cable run proceedure in post #35.I'm about to fit a Brake light with Reversing Camera to a 2013 Beach. I think I've got my head around the upper rear door panel, but was wondering if you had any tips for routing the cable along the near side of the van?
Thanks Borris.I fitted a rear window cam to our 2019 Beach some months ago. There's a brief description of the cable run proceedure in post #35.
