stephen watson
I think this will be a warranty job, but as that might take a day of my time to get there to diagnose and another day to fix, some way away thought I'd ask if anyone knows a fix:
My sink tap has started to work intermittently. There is definitely water in the tank. When you switch it on you hear a slight click (electrical switch?) but then no pump noise or water. Try it a few times and it might work a bit later - with sometimes quite a bit of gurgling and non uniform flow - almost like an airlock but I don't think it is. When the pump runs it always delivers water. I have the VW shower and although I never use it when you flick the switch the pump always starts so I don't think its the pump. Checked the fuse connection under the sink which seems to be firm.
Any ideas anyone please?
