Ch1pbutty
My understanding is that the 2 Seater Beach meets the DVLA rule as has a fixed storage cupboard next to the Bench (water is not required), seems having a fixed high top roof does not actually matter otherwise the Ocean + Coast would fail the test; But I suppose you could go for doubleslider, fit your own awning, fixed kitchen pod behind the driver/passenger seat and apply to the DVLA to have the V5 changed.
Random question...so if you remove the awning from your Beach or Ocean; Is it still considered as a Camper, and is your insurance still valid as technically you have 'modified' your vehicle?!
For a vehicle to be recognised as being converted to a motor caravan it must meet all 4 categories shown below. For DVLA to change the body type, the vehicle must have the external permanent features described in the DVLA guidance for converting a vehicle into a motor caravan.
Category 1: Seats and table (1 example for both)
The seats and table must have the following features:
The sleeping accommodation:
Your conversion must have a minimum of a single ring cooking facility or microwave, which shall be secured directly to the vehicle floor or side wall as a permanent feature.
If the cooking facility is fuelled by an on-board gas supply:
The storage facilities:
Motor caravan external permanent features
This list describes the external features which are commonly seen in motor caravans, and it is intended to provide guidance on what DVLA expects to see when considering your application:
- they shall be an integral part of the vehicle living accommodation area, mounted independently of other items
- a table mounting arrangement shall be secured as a permanent feature, although the table top may be detachable
- permanently secured seating must be fixed to the floor or sidewall and available for use at the table
- shall be an integral part of the vehicle living accommodation area
- can be either beds, or beds converted from seats
- must be secured as a permanent feature, either with the base structure of the vehicle floor or to the side wall, unless the sleeping accommodation is provided over the driver’s cab compartment
- the fuel reservoir must be secured in a storage cupboard or the reservoir secured to the vehicle structure
- the fuel supply pipe must be permanently secured to the vehicle structure
- can be a cupboard or locker
- form an integral part of the vehicle living accommodation, mounted independently of other items, unless incorporated below the seat, sleeping accommodation or cooker
- must be secured permanently to the vehicle floor or side wall except when the storage facility is over the driver’s cab compartment
- 2 or more windows on at least one side of the main body (this does not include windows on the driver or passenger doors) to provide a reasonable amount of daylight into the living accommodation
- a separate door which provides access to the living accommodation of the vehicle (this excludes the driver and passenger doors); a window on this door counts as a separate window on the main body
- motor caravan-style graphics on both sides of the vehicle
- an awning bar attached to either side of the vehicle
- a high-top roof (this does not include a pop-top elevating roof)
