mucksmuff
Maybe I should RTFM)
[/QUOTE] ??????????
Oh Yeah! I had no idea it did this. Such fun to be had in all this hot weatherAnd the same when you lock, you can close the windows![]()
It works automatically when you stop on a hill (or should do). After a couple of seconds though, it releases. First time I noticed it I thought the brakes were bindingHow does the Hill Hold assist work. I've never noticed it, is there a way to get it to kick in?
Just try it on an incline, as you take your foot off the brake and you start to release the clutch it will just hold the Cali so you don't roll back - but only for a second or two! Works well.How does the Hill Hold assist work. I've never noticed it, is there a way to get it to kick in?
AmazedI'd never seen these buttons (between the map reading lights) until just now
This is what they do:-
Don't know how I've managed without them until now![]()
Something I discovered the other day but not sure if its right. Always a little bit vexed by having to lean over and lock all doors by switching the switch on the drivers arm rest before retiring to bed. I tried it doing it with the car keys and surprise surprise the alarms all went off. I have now found a little switch inside the drivers door pillar and I THINK ?? that if I switch this off it deactivates the movement sensor so I can lock internally by my keys (from bed) Hope this works?
Crumbs! Himself is so excited he's just grabbed the keys and Nipped out to see if we have them tooI'd never seen these buttons (between the map reading lights) until just now
At least you haven't paid for something you'll never useCrumbs! Himself is so excited he's just grabbed the keys and Nipped out to see if we have them too
Apparently not![]()
On my LHD 2013 Cali (no alarm) then if I lock via the switch on the driver's door, then open the sliding door (2 pulls on the handle) then the sliding door does NOT lock automatically on closing.You can also lock using the switch on the drivers door, then leave as normal via the sliding door; it unlocks to open and it locks again automatically when closed. Alarm is not activated.
