Bally2811
- Messages
- 39
- Vehicle
- T5 SE 180
We are now on our Second VW California having being an early customer when they first were released and subsequently bought our new 5 seat version in april last year. Now as you will have read the difficulties of moving the 5th seat is painful and storing it for quick overnights even more so, in effect it means brining an awning and storing in there.
So.......following quite an extensive research project I'm glad to say it was finished only at 1pm today and I'm absolutely delighted with the results. Highe thanks to Colin at oxfordt5 and Transcal.
It does not come without its compromises as i will explain later.
Stage one removing the Front Single Seat and Replacing it with a Twin Double folding seat from a Transporter.........
A few considerations.
The twin Passengers seat needs to be modified to house the battery.
Double seat base is only available in black, Cali seats have a grey base?
Front Airbag in a Cali is a single and an upgrade to a double was required, again very simple job.
To install the extra 4 floor studs you need to lower the fuel tank and remove some under trays, quite simple really as all the right holes are there.
You also would need to make 4 holes in the flooring/ carpet but this is covered by the new seat.
You might want to re register the vehicle with dvla by using the amendments section on v5 to 6 seats if you want to keep the middle seat but we didn't so no change required.
Insurance need to be updated but this wasn't a problem with my insurer Safeguard.
You might need to get it retrimmed to match your other seats?
so here are a few photos.....I'm still waiting on the twin passengers seat headrest to be upholstered as i told them it had the wrong ones!
