Little owl1963
I suspect Volkswagen dropped a major boo boo with double burner gas hob , on my California ocean T6.1 , the model number in manual is dometic MO9122 .
Do not have this model if you want cook anything out of a tin in saucepan , it will boil it dry in very short time even on lowest gas setting !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
MAJOR PROBLEM !!!!!!!!!!!!!!!
Upon calling DOMETIC im advised there are 3 burner sizes
auxiliary 47mm diameter for simmer
semi rapid 62mm
Rapid 77mm
The California comes with 2 x identical semi rapid 62 mm burners with butane gas , way too powerful even on low heat , impossible to heat saucepan of baked beans without them being boiled to death on lowest setting .
Im also advised by Domestic most there hobs for campervans / caravans / motor homes come with 2 size burners , 1 x medium and 1 x small or simmer .
I would advise anyone considering to buy a cali to bear this in mind , and anyone who has brought one to email Volkswagen to either put this right or recall all vans to be rectified .
After all what's point spending £65,000 plus only to find out you cant even , use a saucepan with something out tin , without it being boiled death on a low simmer setting !!!!!!!!!!!!!!!!!!
The cooker should have been supplied with 1 x medium burner and 1 x small simmer burner to use with saucepan .
I have emailed both Volkswagen and dome tic today to see , if can rectify this issue , by fitting either a smaller simmer burner , or possibly
a smaller injector .
Not very happy at all , i can not simmer tinned food slowly an gently for 7 mins on low heat as per instructions on tin , only bring it to an instant boil destroying the taste an goodness in food .
I urge anyone same problem contact Volkswagen , who designs there products i will never no ????????????????
semi rapid 62mm
Rapid 77mm
Good man.
