Yes, good point Denzilgts, in the van or on a gas stove everything is very controllable and you can get the heat nice and low. I was thinking more along the lines of when using over charcoal or with fire outside the van.We have done loads of cheese toasties , bacon ( if fat comes off just pour it away and continue cooking) , great for deep pan pizzas from the freezer aisle.
I only use the heat on the lowest setting works absolutely fine , no splatter and reduced steam in the van .
Do you cook the pizzas from frozen or let them defrost first, Dezilgts?We have done loads of cheese toasties , bacon ( if fat comes off just pour it away and continue cooking) , great for deep pan pizzas from the freezer aisle.
I can see your point, Bigmac, and I think it depends what you’re cooking. If you’re frying and don’t want the steam trapped in (if your monkey is closed) you’d be much better with a good frying pan. But you can use them as a kind of mini oven and cook all sorts. Also, when closed you can just flip them, which I really like. I also like that the lid is attached (so I can’t lose it or forget it).I bought a Ridge Monkey and we took it away with us for our long summer holiday. Turns out that it offers very little over a normal frying pan and a lid and frying pans are bigger. Waste of money IMO.
What “monkey” do you have? Mine are the old XLs and I’ve been so impressed with them. As you’ve said, no splatter and steam - brilliant. I have been looking at the new ones that split and that larger combo pan with compartments. When I saw it in the shop I was surprised how big it was (I think it would be really versatile, especially as when split you would have 2 good size pans).
Do you put your bread slices on top of each other, Steve and Lisa, do one side and then turn them face out for the other?We also use ours for pizza, we cut them to size and cook one at a time, they are ready within a few minutes (you need to keep turning the RM over)
Also for toast, we have perfected it with two slices of toast ready in under 2 minutes.
For such a simple device, the possibilities are endless
OMG! I didn’t know the new ones had detachable handles. That makes them even better. Fixed handles on mine make them harder to store effectively. Thanks for the heads up, Aubergine-ine.I have these new ones. The handles fit inside the pan! The pans perfectly fit both Ocean gas pits, even without splitting them. Lots of picts around here. Definitely not too big. Splitting both pans is a bit of a trick, but you get used.
Looked at the pics. Love where you’ve put your fresh herbs. What container are they in and how have you attached them?I would agree, if your pans would be square, you could remove the handles, you could flip them over for the tortillas, and they could contain rectangular envelopes...
To me square items have just more useful surface for less storage volume. For the same reason I have my plates also square.
View attachment 37891 View attachment 37890
Wow, great video, Matt. One monkey and all that food, brilliant. Patrick’s workspace was so organised.3 courses apparently on the latest model
We heat pasties in a frying pan!You can’t heat a couple of pasties in a frying pan
Or spring rolls, sausage rolls, part baked rolls etc
But when you flip it over your pasties would fall out!We heat pasties in a frying pan!
We just put frozen pizza in fridge before we leave home.. usually when we get to the site and need them they are chilled . Straight into the monkey. Works every time , do prefer the pepperoni pizzas , even better with more cheeseDo you cook the pizzas from frozen or let them defrost first, Dezilgts?
That would be great, Matt. It’s always good to have some starter points. I’m using his photos from another thread to work out measurements for other things I‘d like to do when I get my Cali. A video would be really useful and help me to put things into perspective.Haha I have footage for a video about Patrick’s organisation of the Cali. ;-) very good use of space. A very different situation to my own organisation haha
Will be interesting. He’s very inventive.That would be great, Matt. It’s always good to have some starter points. I’m using his photos from another thread to work out measurements for other things I‘d like to do when I get my Cali. A video would be really useful and help me to put things into perspective.
I have 2 of the old non-removable handled XLs in the kitchen at home. For our new van I bought the new XL and the combi pan. But, I found the combi took a lot of storage space and I already have 2 brilliant tefal ingenio fry pans, I also didn’t think it would be versatile enough with its “static” compartments, so I took the combi back.Should I buy a RidgeMonkey Deep Fill Sandwich Toaster XL or a RidgeMonkey Connect Non Stick Combi Pan? Can you cook a toasty in the connect combi?
I like the idea of the detachable handles & that the combi can be used as two separate pans, but is it as good as the original design?
On the new versions the handles detach.A normal pan is easyer to wash up , as the two sides are not detacheble neighter the handle ....but still a good thing to carry imo.
Good thinking, motorcyclist.I’ve done those “Petit Pans” in ours (the ones that are half baked). Quite handy to carry because they have a long shelf life, so if you run out of bread you can use those.
I very nearly did that too! Maybe we should attach a piece of bright coloured tape to the tool set so it sticks out to indicate they’re inside!
