I hope your gearbox and cranckshaft will cope with the extra undamped forces from gear changes.What’s in the box?
New clutch, solid flywheel kit from Valeo, getting rid of the DMF sing, too short a life and expensive, the kit is cheaper than an original LuX DMF and next time only need to change the disc and clutch cover.
And an excuse to get a new toy, a 2t trolly jack
I could agree with you if I had an earlier T4 Tdi which basically had a golf gearbox with larger diff with no other changes apart from a new housing and were never designed for torque of the 2.5Tdi ACV of 250Nm and quite a bit more if decat’d.I hope your gearbox and cranckshaft will cope with the extra undamped forces from gear changes.
DMF is fitted because of lighter material in gearbox.
If you change gears sporty, it might lower the lifespan of the gearbox.
I had my Golf 4 converted into a solid flywheel, and in gear changes I really felt the shocks. Sold it later on for my California.
I will never change the DMF to a solid one. Yes the price will be the same of the complete solid kit, but I won't sacrifice gear change comfort and lifespan of the gearbox.
No issues yet at 145000 km (90000mi).
Let us know how it feels while driving.
And solar panel 120W + mppt
Hi Calimili. What are you charging with this panel?
Hi Elly, I am charging the leisure batteries with it.Hi Calimili. What are you charging with this panel?
You won’t regret it!Ordered Isotop Mark VI....
long delivery times though, 4-6 weeks
Hi,Hi Elly, I am charging the leisure batteries with it.
I've connected it to the rear battery for the moment, but I plan to attach it to the front leisure battery with an anderson plug. Then i can easily disconnect and connect it with clamps to the motor battery should i need to charge or top up that one too
DanNish does this mean that you might be better with the 760 mm set up if ordering for an ocean or you just need a smaller box on that side (just trying to work out the relative merits/cons ) ?View attachment 37160
Thanks very much for all the info Loz!
Tiled Garage floor, very nice.What’s in the box?
Hi Kirstie, on a Ocean the front battery is under the left seat in the cockpit, the rear battery is at the bootom of the wardrobe, there is a hatch to open down there left side of the boot.Hi,
I’ve been looking at something like this, where are the rear /front batteries and how did you connect it to them? I had a roof solar panel on a previous van, but don’t really want the additional expense at £500.
Kind regards, Kirstie
I get jealous of nice garages too. Mines full of junk with a leaky flat roof. I dream of a garage with one of those posh floors. Loads of lights and enough room to park my van in. Sigh. One day.Tiled Garage floor, very nice.
Do you think it will charge effectively through the glass, Calimili?Hi Elly, I am charging the leisure batteries with it.
It will charge slightly less, but it charge nevertheless.Do you think it will charge effectively through the glass, Calimili?
Fantastic, looks like my first garage which was nearly as big as the house but over the years the houses have got bigger and the garages smaller, think I went wrong somewhere.My garage was build to fit cars arround 2m h. as at the time my Defender with roofrack and tent needed to fit and i knew a Cali was on the list of cars to come....
So i had this build :
It's 100m2 floor (polished concrete) and one open space inside without walls or pilars.
The door is 6m wide and 2,30m h clearance .
On top an attic....
For the moment it fits 3 cars and lots of Cali-related stuff , DIY stuff , tools , workbench,...
I kind of got the garage for the Cali so staying on topic![]()
Very nicePixers stickers to brighten up our table tops
