Those are projector LED lights. They do not need stickers as LEDs throw a flat beam.We're travelling to the EU tomorrow, and I've bought a set of the Eurolite stickers for our 2016 California Ocean, but I can't work out if my headlights are considered standard or Projector/Xenon, as per the instruction list for the Eurolites.
Can anyone help from these photos please?
Those are LED but on a T6 they are not a flat beam . On that model in the system settings there should be a "travel mode" that you need to turn on that sorts the lights out.Those are projector LED lights. They do not need stickers as LEDs throw a flat beam.
If in doubt, put as per Xenon instructions.
You can tell by looking at them, no need for a data sheet.Do LED lights have washers?
You should be able to tell from the data sheet in front of the handbook.
Mine are 8EC which is "bi functional headlight with gas discharge lamp for driving on the left".
It should be possible to decode on igorweb.org/equidec.aspx
Sometimes! My old 2019 Octavia had LEDs and washers, while my 6.1 Ocean has LEDs but no washers (don't miss them - never convinced they were that effective for normal road grime and they gobbled washer fluid. Might work better with muddy water I suppose)Do LED lights have washers?
