markh
- Messages
- 253
Hi Andy
I'm pretty sure my Cali (2012) has a Webasto Airtop as the standard heater, or at least that's what it says on the inside of the door. I'll check again tomorrow though.
As you say, it should be possible to fit this just using levelling ramps. I just don't fancy lying on the floor doing it in this weather since I don't have a garage or anything to do it in. I think, it might need a bit of time underneath the van since you need to lower the heater and then fiddle around with wires/plugs etc. to connect it up. Let me know how you get on though if you do do it as I might give it a bash next summer.
Cheers
Mark
P.S. Also, it's not just the heater that uses the battery. It's also the fans for blowing the air into the cab. It might still be viable though if you don't do too many short journeys after using it.
Cheers
Mark
