Jabberwocky
Forever young (ish!)
Sorry but I don't get it - the use of pressure washers that is. Using a pressure washer on a car/Cali? They will do one of two things. Push water/foam/grit where you don't want it and/or damage a vital parts of your beloved Cali. They certainly will not save you having to wash your car/Cali in the conventional way. If your Cali gets very muddy or covered in salt have patience and soak with a gentle hose down - leave, then hose down again to get rid of grit etc, then wash in the normal way. By the way you should always use a foaming cleaner with a lubricant - minimises the scratches and swirl marks. Start with the roof and work downwards to the sills - do the wheels/wheel arches last. TLC is the answer not front on attack! Save the pressure washer for the patio or path (with care even here!). This post is not intended to be a hand grenade but recognises the potential!
