sidepod
- Messages
- 6,914
- Vehicle
- T4 PopTop
Hmmmm? I wonder if, just for giggles, VW carried out rear impact tests to comply with Euro law for that type of vehicle fitted with gas bottles?
Beach owners don't of course have this dilemma![]()
I will have in the new yearBeach owners don't of course have this dilemma![]()
Plus a selection of heaters, fridges, drawer units, storage crates etc.....No … but some might have a loose gas bottle coming around in an accident …![]()
Apart from the danger of ruptured gas lines in the event of an accident, there is also the possibility of leakage from one of the joints, leading to gas build up in the kitchen units.
The leakage of gas from the bottle is very real, I had the use of an explosive gas detector for a spell and left it in the gas compartment while it was turned on for a cuppa. Before the kettle was boiled the alarm was going off and fortunately I was able to tighten everything up and the escape was stopped.
Yes that's true. But being tight, I could bear the waste of gas!n this case, when the gas is inside the water tank, the gas should be able to escape thru the hole in the bottom, because gas is heavier than air.
Thanks Kmann. That's quite a task (as it is in mine). I doubt it's beyond man's ability to design something simpler than would encourage greater compliance.@T4WFA: We open the rear closet, remove the shelf, open the security lid in the water tank, and turn of the gas on the valve (some even unmount the valve).
Depends on the country! In France it's forbidden to drive with an open gas bottle, for example.
Incidentally, the one I was using had four sensors and also checked for oxygen level, hydrogen sulphide gas and carbon monoxide. While I had it, I tried it inside the van and found that there was a significant reduction in oxygen levels, so now I always open one of the windows slightly. (Had I read the manual it says to do this anywayI guess a gas detector is a good thing to have in the car, if you carry gas.
Useless poll? The main reason I use this forum is my interest in what other people do. The poll function is therefore very "useful". Furthermore, once I've read the arguments for and against, I then form my own opinion as to what I think is best. I think I'm with the majority here.Sure it is , like many other useless polls.
Just do what you think is best , others don't bother what you do , some don't even bother things they do themselves...
Agree and looking at the line runs, materials used and length of the respective lines then the chance of a gas line open rupture compared with a fuel line rupture is minimal.Possibly more likely that the fuel or gas lines will rupture before the gas cylinder or fuel tank. Vehicle fuel has to be pumped out whereas the gas will discharge itself if the line goes with the valve open.
A cellar is the last place you should be storing a gas bottle, If the valve leaks you will fill the cellar with gas and as its heavier than air it will just collect at the lowest point until you ignite it by turning on the lights. Best place is outside so any gas can disperse.Turned off and disconnected when driving or even remove the bottle during winter (and store it in the cellar).
A cellar is the last place you .... Best place is outside so any gas can disperse.
I think you will find that storing it at low temperatures will do No harm. Temperature is more important when using it at cold temperatures.Good point andyinlution. Thanks for that. I am going to keep it in the bike shack - outside. With plenty of fresh air. I only have to check what the temperature limit is (we sometimes do ha e -15 Celcius).
