That time of the year, but the garden and lawn still too sodden, so decided to remove my 17” Steel Spare with 235x55 tyre and clean it, rub it down and apply some Hammerite paint.
So, undo captive bolt on L side - no problem, unscrewed about 1.5 cm.
Removed dust cap on R side Locking Bolt and using Socket key removed bolt and Safelock.
Using Tool Kit wheel wrench fitted into wheel carrier lift and slide to the L to disengage Carrier from the captive bolt. No problem and lowered to the ground with the Wheel wrench still in place.
Then fun and games. Couldn’t slide the wheel out because of the Captive Bolt AND the Towbar Electrics Socket were in the way and the Wheel wrench was holding the carrier up slightly. With great difficulty and a large screw driver managed to lift carrier and remove Wheel wrench. Still not enough room so had to resort to jacking the Rear Nearside up so I could get the wheel out.
The Wheel was in quit good condition after almost 3.5 years and 65,000 miles. A good clean with the water jet, wire brush and 2 coats of Hammer finish Silver Hammerite and it looked like new. The wheel has been out before but at the local tyre fitters but not on the driveway before.
Also SafeLock cleaned, wire brushed and coated in Red Enamel paint.
SO, if you have a flat tyre then remove the spare first , especially if the damaged tyre is on the front.
How those who have lowered suspension manage I do not know, but I doubt if many carry a Spare. If you do check to see how easy or not it is to get the Spare wheel out in anger.
Have Fun
Have Fun
