Calihunter
Right folks, the update you have all been waiting for!
Got the van back this afternoon after being at AB Crush.
Before I go any further, I must say I found them to be excellent in their customer service and reassuring when I raised concerns. They returned my calls as promised and went to great lengths in explaining what was going on and how they were taking great care of my pride and joy!
Now for the van...
They have obviously looked after it really well (wrapped up like a baby was their words) and this is evident as there are absolutely no marks anywhere, inside or out, on the canvas or anywhere else. If any of the interior trims, control panel, headlining or anything else was, removed you wouldn't know it as they have been put back perfectly.
The finish on the paintwork is excellent and the there is no over spray visible anywhere, so again, top marks.
Now the repair itself...
The new cap fits very well and the gap between it and the top of the windscreen appears to be the same as before, with no visible sealant.
The cap appears to sit slightly higher on the trailing edge, and this is to be expected if it is fitted over the original. The original channel behind the new cap is retained and does not appear to have been disturbed.
Now the disappointing part....
The new sealant used between the rear of the new cap and the original channel is black!! Whilst it has been applied neatly it does show and would be better if it was sprayed to match the vehicle! This is the only minor criticism I have of AB Crush.
Now the really annoying part....
The new replacement rubber seal does not fill the gap between the new cap and the pop-up roof. There is a gap of nearly half inch (real money) which means it doesn't cover the black sealant mentioned above. In addition to this, the rubber seal does not form a seal at all as it does not sit properly in the the bottom of the channel and looks a mess. I don't remember there being such a gap with the old seal?
I think this gap may also lead to excess wind noise?
AB Crush can only work with what they have been given, so again, I have no criticism of them regarding the new replacement seal. The design of the seal is such that it just doesn't appear to be up to the job!
I will try and post some before and after pics to make my ramblings a little clearer.
Now for the van...
