Loz
According to the workshop manual;Being lazy and not gone to get the manual. What is the capacity of Ad Blue tank?
Mike
AdBlue® tank run empty
approx. 13 litres
AdBlue® tank renewed
approx. 15 litres
Mike
TaAccording to the workshop manual;
AdBlue tank run empty
approx. 13 litres
AdBlue tank renewed
approx. 15 litres
I've used a pump at a BP garage to top up a VW Sharan. 49.5p per litre. Quite a fast flow and a stiff hose - the filler on the Sharan is inside a panel in the boot area, so was quite a delicate procedure.
Yes, I've used the HGV Adblue pump at a Shell garage in Sheffield twice now. Worked exactly the same as filling up from a 'normal' diesel pump. Flow rate seemed the same, didn't need to feather the flow in any way. And I wasn't questioned at all by the garage when I paid. Also, several colleagues at work fill their diesel Passats up with Adblue from there. This excuse by Shell HQ regarding flow rate sounds dubious to me.
I can find many "Truck" Ad Blue stations but do they not have oversized delivery nozzles? No good for us Calis? Are we in the process of being stitched up from a price point of view.
And if I am honest I do not feel like even paying Halford prices!
Where is the cheapest ISO compliant Ad Blue?
Thx GJ. I like the 69p. Just need to find the local Shell outlet with Cali friendly nozzles.Depending on where you are it is 69p from the nozzle or 99p from Amazon.
For the convenience when i picked Alfie up I had 20l of Ad Blu delivered from Amazon, compliant with the ISO that VW specify. Shell have now opened up two Ad Blu stations in Chichester so I can just fill from the pump instead.
7,000 miles and I have unscrewed the blue filler cap twice. Nothing for me to get excited about.
Oooo.....I like both bits of info here! Truck nozzles fit Calis and 30/40 pence per litre. Maybe I will wait to fill up until I get to Holland.I think all AdBlue nozzles are the same size - truck nozzles fit just fine.
Rip-off Britain? You should be paying 30 to 40 pence per litre. That's the usual price in continental Europe. 20% VAT, but I cannot see a justification for fuel duty being charged on AdBlue. Does anyone know if it attracts duty?
Thx Tom
OK, thx. Will investigate further.......I've never filled with AdBlue in the Netherlands, in Slovakia I paid 35 cents per litre.
No problem at all. It only takes a few seconds to fill up and it's cheap!I can only answer for the nozzle at Magor Services. It was perfect for the Cali, fitted in neatly and clicked off when it was full. My biggest fear with using the bottles is overfilling with AdBlue. The pump was very strange compared to fuel pumps though, you have to slide a large cover up which then reveals the nozzle. I suppose that is to make it totally obvious that it is not diesel. But quite a few on the Forum fill up from garages, I know that @Borris does and he has not mentioned a problem.
I've not really looked for one in Canterbury. I'd try the Gate Services at Dunkirk on the A2. They have a lot of lorry traffic so will almost certainly have an Adblue pump. We live in a village just outside of Canterbury but I usually fill up the Adblue tank at the BP station on the A20 at the western end of Dover. Their fuel is usually cheaper as well.HI Boris. Where do you fill up? We're from the same area and so keen to find out if you've found an Adblue pump in the Canterbury area. thanks
I just top it up from the pump until its full. I've haven't had any issues so far.I have also now found this site that has locations of "Air1" AdBlue ( http://uk.air1.info/en/adblue-supply/adblue-filling/ ).
It seems that all locations shown have pumps. They even have a section on the web site where price is discussed!
Anyway it may be useful to all that are rather confused or apprehensive about the AdBlue topping up task (including me!) especially after reading the owners manual which seems to suggest that you must not top up with less than the minimum shown on the dash display or more than the maximum.
Edit: A bonus! - the Web Site is updated monthly so should be pretty accurate.
