Trev
- Messages
- 265
- Vehicle
- T6 Ocean 150
We’ve had problems re coolant warning light and wondered if anyone else has experienced similar. In summary: coolant light started flashing. Pulled over coolant slightly below minimum level. Allowed engine to cool. Opened coolant chamber. Topped up with a few drops. Carries on. Repeat x 3. Next time coolant was very low and topped up. Happened again and eventually limped Home followed by VW assist (top man). VW couldn’t really find a problem but replaced most of the cooling system because VW assist had added sealant to the coolant reservoir. Couple of weeks later warning light and MFD warning to check coolant. Engine cooled and coolant was a little below min level. Released reservoir filler cap and coolant rose to min level. Patience wearing thin so back to VW. They couldn’t find a problem and think the coolant rising when filler cap is released is “coolant coming from pipes in the system and finding its own level”. I challenged them that either the coolant level is correct or the warning light/sensor is faulty. They can’t both be right. Have a feeling I’m being fobbed off and I’m just waiting for it to happen again. Anyone had a similar experience or someone with technical expertise that has a view? Thanks in advance.
