Trev
- Messages
- 265
- Vehicle
- T6 Ocean 150
Dealer has confirmed engine ordered and due to arrive this week. Will be fitted next week. And I will make sure they confirm they have set the ECU properly.
I wish you the most wonderful luck with your new camper.Latest update on the saga .....
New engine fitted.
Problem occurred again on half term trip away.
Back to dealer. Hours on the phone to dealer and VWCS. Long story short (and believe me even this chapter is a looong story) VW and dealer have agreed to replace vehicle with £ contribution from me. I had to keep politely but firmly pushing. Having sunk so much money into buying the Cali there was no way I was being fobbed off with continual repairs. All involved agreed no one could be confident they could fix the problem. VW contribution was about £400 more than mine! They effectively put it all on the dealer. The dealer eventually came up trumps as they have had to swallow a lot of £ on this case. New vehicle arrives in a few weeks. Fingers crossed for this one. Another interesting nugget of info in all of this is the division between VW (the brand) and the dealer. Customers get shunted between the two. Apparently though some dealers are still owned by VW (not in this case) but worth knowing if any of you get told it’s for the other party to sort out if you have problems (“they” may be the same “party”).
Many thanks. Can’t wait for it to arrive.I wish you the most wonderful luck with your new camper.
Likewise we have had many previous VWs and currently a couple of Skoda’s all problem free. It’s being repaired but was put on a private plate from new which we are keeping.Finally you get a good outcome. Increasingly I find VW Group a bit of of a corrupt shambles. I own porsche skoda and VW but the shine is gone. Whats happening to your old one ? If its to be resold then it would be good to publicise the reg number on here once your past the point of any U turn.
Good point!Finally you get a good outcome. Increasingly I find VW Group a bit of of a corrupt shambles. I own porsche skoda and VW but the shine is gone. Whats happening to your old one ? If its to be resold then it would be good to publicise the reg number on here once your past the point of any U turn.
Yes it is a big job. When I had my first coolant problem the dealer said they couldn’t find a problem but it could be the cylinder head but “it’s a big job” to remove and check hence they didn’t and eventually a new engine and the saga continued.Hi, just wondering, is it expensive for the mechanic to find out if you have a leaking egr cooler or cracked cylinder heads? Have had a drop in coolant recently and vw found no problems on initial inspection and topped it up, but level has dropped again after 200miles? Thought I may take it in again and suggest what they should look at.
Check your engine oil level from time to time. If your engine oil level rises, you might have an oil cooler leak inside the engine.Hi, just wondering, is it expensive for the mechanic to find out if you have a leaking egr cooler or cracked cylinder heads? Have had a drop in coolant recently and vw found no problems on initial inspection and topped it up, but level has dropped again after 200miles? Thought I may take it in again and suggest what they should look at.
This might be the airco outlet at the front. If it is clear, it is probably airco, or just water outlet from the roof.I see this damp circle on the ground and a very slow drip (above the glass). Am trying to catch some to check if it’s pink
Is the oil plug of the sump easy to get at without a lift? Maybe I should give that a check before spending money on a mechanic.This might be the airco outlet at the front. If it is clear, it is probably airco, or just water outlet from the roof.
If it is pink, there will be a leak, but that is a very unusual place to leak coolant.
With coolant in the oil, your engine will not be running bad, unless it gets really overfilled (2 to 5 liters).
Check your dipstick. If it is above maximum, there might be coolant in the sump. This you could check by unscrewing the oil plug of the sump, and catch the oil. If it is water or pink first, then you have coolant in the engine oil, because the oil is lighter than water, the water sinks to the bottom and the oil stays on top of it.
Don't want to worry you, but those engines MIGHT have that problem. Otherwise keep searching for external leakage.
Im at the plug, just wondering if I slowly unscrew it, can I go till it drips and tighten again or is it an all or nothing and I have to let all the oil out?I hope it is not what I think it is, but on the other hand, than you will know what is causing the coolant shortage.
If you have coolant in your engine oil, it will most probably be the enging oil cooler. Then you will need to replace that part (the part where the oil filter is mounted on), including a new seal!
Also check if there is a smell coming frIndeed.
Might be another problem then.
Carefully check all hoses, connections to the engine block, radiator, coolant reservoir for pinkish traces.
Also check if it smells odd when you put the heater on, which may indicate a leak in the heater matrix.Indeed.
