Solar Panels
John Georgiou
Hartford Huntingdon
I am a new Cali owner and would like some advice regarding Solar Panels. Which is the best way forward, Fixed panel or Free standing? 100w or 120w, Any advice would be welcomed
We have two 100w panels bolted onto the roof rails, keeping the leisure battery topped up during daylight hours. Our fridge is kept on and we have never had any power issues from leaving it on. We don't hook-up every month as recommended in the manual, and have camped as a family of four for 6 nights without hookup relying on our single Beach battery for refrigeration, lighting, and charging of iPhones, iPads and a laptop.
Problems arose when we tried boiling water with a 12 volt kettle while camped under a tree - doh!
For a trouble free kit, or to get ideas of your own:
https://www.solarcampersolutions.co.uk/
There are pros and cons to each solutions. Some initial thoughts from me. Either solution is good its just what suits you best.
Fixed Panel
Pros
Always on, will continually put charge into your batteries
Fit and forget
Wiring hidden away
Cons
Fixed panel will not often get maximum efficiency as it will not always be facing the sun perfectly.
You may not want to park the van in hot sun but shade will hinder the panel
Free standing
Pros
Free standing can be positioned and moved throughout the day for optimum power output and only used when required.
Can be placed in the sun with van out of the sun.
Can be used with different vehicles or at home too.
Cons
Not always on
More easily stolen?
Have to setup and takedown each time.
Wires will need to be directed outside (open window?)
I would probably say fixed is easiest fix and forget solution to be honest, you may just need higher capacity than a free standing panel to get the same power output.
Hi john, A minimum of 200w semi flexible on the roof, fit and forget, you will get the same output on a dull day from a free standing 100w panel constantly angled towards the sun, but were are you going to stow it in the van, how many times are you going to move it to follow the suns track and are you going to lock it tp the van ...
My solution is to fit one on the roof rails, but only fit it for holidays or extended travel, not make it a permanent installation. I find the leisure battery's are good for 3-4 days in winter without hook up.
Why keep removing it? What do you hope to gain from constantly fitting and removing it?
Yes and moreover, if you kept it fitted you wouldn't need to worry about keeping your main and leisure batteries tickle charged when you're not using the van... no? (Unless of course you store your Cali in a garage).
Van is a daily drive, as its fairly new don't want to butcher the flexi boots to run a cable through, wind drag, and keeping the van clean, each to their own but that's my take on it.
Understood Nick, it occurred to me after I posted that you might use your van daily, and anyway I'm sure you know what you want. :happy I just wanted to highlight for the OP that putting panels on and off is an unusual choice and I'm sure most people just leave them on permanently.
(Full disclosure: we don't actually have solar: have looked into it but the way we tend to use our van - almost always doing significant mileage every day when touring so batteries almost full every time we stop for the night - means there would be little real benefit in our case).
That is part of the reason I have a fold away. We have two T25s too and can move the panel between vans as we need. The CTEK adapters mean each one is plug and play too.
When driving normally the battery is always full, even with trackers. It's only when we are onsite for an extended time that the 120w folding panel comes into its own allowing us to have a far longer extended stay without hookup. In fact if the sun is out we generally have full batteries by mid morning even with the fridge on. Different story in autumn/winter of course.
You only have to make an incision in the boot about 1cm long, that "self heals" if you remove the cable.
In our kits we also suggest shutting the cable in the boot if you want a more temporary install, or, just slide the cable in in under the rubber boot entry point. No boot cutting then, and you can stow the cable in the roof space behind the grommet/boot if you only occasionally have the panel bolted on.
In my experience, the big con with folding / temporary panels is you either forget to put them out, or, have to put them away a lot of the time they could be working, because you don't want them stolen.
Roof panels (two x 120 w) produced just over 700 watt of electricity today. Van is positioned SW with roof up, cloudless sky in main and no shadow middle of France (Auxerre). This seems pretty good to me.
The dark cloud was that tap micro switch has failed!
Can I ask did you install the kit yourself. I had a quick look at the roof mounting side of it and that all seems very straightforward. The bit I’m not so sure about is the installation of the control unit and hooking that up to the leisure battery
Appreciating that this is an old thread but this video may answer a number of questions some may have if searching for solar solutions.
I got my engineer brother to help me.
It was really very easy... I made the coffee.
If you drop me a message through my website I'll email you the instructions. Its all very easy.
R
I did mine myself. Roger's instructions are pretty straightforward. Getting down behind the cupboard to the leisure battery is fiddly but not hard. Getting the leisure battery to a position where it can be accessed is tricky because it's such a tight fit in the Ocean.
Hello @Roger Donoghue
Was wondering if you managed to install the solar panels so that the actual VW battery voltage reading was in real time rather than having to start the vehicle to get true battery reading? It was the method @Loz used with good results.
We have two 100w flexi panels. One fixed on the roof and the other simply plugs into a socket in the boot. The panel lives under the roof mattress when not in use. Best of both worlds as the non fuxed one can just be moved to the best position.
I’m not sure what you mean. My Control Panel will show the Solar Panel voltage without starting the vehicle and the MPPT controller display shows the same information + the solar panel output, once again without requiring the ignition On.
Apols. Perhaps I was not too clear @WelshGas. When camped up without ehu, the control panel reads the leisure battery voltage as it would be if there were no solar imput ie every day the voltage reduces. However, turn on the ignition and the control panel immediately recognises the true voltage of the leisure batteries that have been charged by the solar panels. Turn the ignition off and the control panel again becomes blindsided to the solar imput and will reduce voltage number according to how much it 'thinks' the leisure batteries are using from fridge etc. Does that make sense? @Loz wired his solars differently and it does not do have the blindspot. @Roger Donoghue said he would look into this phenomena and I was wondering if he had done so.
Cheers
Cheers
Interesting. My Control Panel voltage mimics the Solar Panel MPPT voltage etc, irrespective of whether Ignition is On or Off. Must be a T6 thing.
I think we are referring to attaching the solar negative to chassis and not directly to the battery so as not to bypass the shunt that the control panel is using to calculate SOC.
P
OllieCollieCali
Californication69
Californication69
