John Georgiou
I am a new Cali owner and would like some advice regarding Solar Panels. Which is the best way forward, Fixed panel or Free standing? 100w or 120w, Any advice would be welcomed
We have two 100w panels bolted onto the roof rails, keeping the leisure battery topped up during daylight hours. Our fridge is kept on and we have never had any power issues from leaving it on. We don't hook-up every month as recommended in the manual, and have camped as a family of four for 6 nights without hookup relying on our single Beach battery for refrigeration, lighting, and charging of iPhones, iPads and a laptop.I am a new Cali owner and would like some advice regarding Solar Panels. Which is the best way forward, Fixed panel or Free standing? 100w or 120w, Any advice would be welcomed
Why keep removing it? What do you hope to gain from constantly fitting and removing it?My solution is to fit one on the roof rails, but only fit it for holidays or extended travel, not make it a permanent installation. I find the leisure battery's are good for 3-4 days in winter without hook up.
Van is a daily drive, as its fairly new don't want to butcher the flexi boots to run a cable through, wind drag, and keeping the van clean, each to their own but that's my take on it.
I just wanted to highlight for the OP that putting panels on and off is an unusual choice and I'm sure most people just leave them on permanently.Van is a daily drive, as its fairly new don't want to butcher the flexi boots to run a cable through, wind drag, and keeping the van clean, each to their own but that's my take on it.
Can I ask did you install the kit yourself. I had a quick look at the roof mounting side of it and that all seems very straightforward. The bit I’m not so sure about is the installation of the control unit and hooking that up to the leisure batteryWe have two 100w panels bolted onto the roof rails, keeping the leisure battery topped up during daylight hours. Our fridge is kept on and we have never had any power issues from leaving it on. We don't hook-up every month as recommended in the manual, and have camped as a family of four for 6 nights without hookup relying on our single Beach battery for refrigeration, lighting, and charging of iPhones, iPads and a laptop.
Problems arose when we tried boiling water with a 12 volt kettle while camped under a tree - doh!
For a trouble free kit, or to get ideas of your own:
https://www.solarcampersolutions.co.uk/
I got my engineer brother to help me.Can I ask did you install the kit yourself. I had a quick look at the roof mounting side of it and that all seems very straightforward. The bit I’m not so sure about is the installation of the control unit and hooking that up to the leisure battery
If you drop me a message through my website I'll email you the instructions. Its all very easy.Can I ask did you install the kit yourself. I had a quick look at the roof mounting side of it and that all seems very straightforward. The bit I’m not so sure about is the installation of the control unit and hooking that up to the leisure battery
Near Taunton I believe.Not sure if you have videos @Roger Donoghue or where you are based but if you ever fancy a collaboration, I think it would be something folks are clearly interested in.
I’m not sure what you mean. My Control Panel will show the Solar Panel voltage without starting the vehicle and the MPPT controller display shows the same information + the solar panel output, once again without requiring the ignition On.Hello @Roger Donoghue
Was wondering if you managed to install the solar panels so that the actual VW battery voltage reading was in real time rather than having to start the vehicle to get true battery reading? It was the method @Loz used with good results.
Interesting. My Control Panel voltage mimics the Solar Panel MPPT voltage etc, irrespective of whether Ignition is On or Off. Must be a T6 thing.Apols. Perhaps I was not too clear @WelshGas. When camped up without ehu, the control panel reads the leisure battery voltage as it would be if there were no solar imput ie every day the voltage reduces. However, turn on the ignition and the control panel immediately recognises the true voltage of the leisure batteries that have been charged by the solar panels. Turn the ignition off and the control panel again becomes blindsided to the solar imput and will reduce voltage number according to how much it 'thinks' the leisure batteries are using from fridge etc. Does that make sense? @Loz wired his solars differently and it does not do have the blindspot. @Roger Donoghue said he would look into this phenomena and I was wondering if he had done so.
Cheers
