It appeared to be the metal to metal contact that was making the noise, the area between the plastic caps that you strapped down.Thanks BJG,
I have tried something similar with ours although I will give your idea a go as well. What I've also done is to fit these rubber bands to each end. They cut down any movement to the minimum.
View attachment 43274View attachment 43275
They are merely wrist bands that are used at various events, often with a message or sponsor printed on them. You can get them from Ebay in all sorts of colours and they don't cost much at all.
Hi Boris, I had the exact same problem.Having posted many times about this rattle issue I am starting to think that maybe it is a design feature. I have had our Cali for nearly three years now and that rattle has been there since day one. To be frank I have all but given up trying to fix it.
In my case the noise concerned seems to emanate from high up on the B pillar next to my right ear. Having taken advise from members of this forum I have carried out the following:
AWNING
1. Adjustment of the awning arms.
2. Sound deadening the awning mechanism with copious felt buffer pads.
3. Large rubber bands round each end of the awning cassette to stop it opening up and thus rattling.
4. Replacing the unreliable sticky rubber buffer pads inside the awning cassette with better ones.
All of this work had no effect on said rattle however it did eliminate the awning as the cause.
SLIDING DOOR
5. On at least three occassions I have referred the rattle to the dealer for rectification. The first two occasions resulted in some minor fettling and adjustment followed by a test run. Both times the service manager declared the issue resolved. Result - rattle still present! On the last occasion I insisted that the sliding door location plates on the B post along with the corresponding other halves on the door itself were changed and adjusted. The service manager again declared the issue resolved. Result - rattle still present!
I am now thinking that the culprit could be the nylon wheel that runs in the front upper sliding door guide track. If the door is half open and you shake the sliding door rapidly from N/S to O/S there is some slack and a similar noise can be heard. However as the nylon wheel is a set diameter and the guide track a set factory pressing I don't see how it can be resolved. I assume any slack could be adjusted out by altering the aforementioned door location plates however I have lost all faith in VW to do this. Any ideas?
Sorry about the bold lettering but I can't seem to be able to revert to normal type.
Thanks for the “heads up”, HC.We heard a tapping noise comming from the rightside while driving over bumps .
Seems it can be caused by the wind out awning.
It is sometimes enough to wind the awning out a bit and roll back in to solve this .
When i rolled mine fully out to let it dry afther our recent Wales trip , i discoverd there are four rubber paddings glued inside the awninghousing that are in place to support the foldable arms.
Seems one of those paddings came lose and probally the arm was rubbing and tapping against the housing making noises....
Roll out fully , look in the middle of the lenght of the housing .
You can see a scrubbed part where the arm was frictioning against.
Glued the padding back on , things to keep an eye on
As you can see there are two paddings on the bottom also where the arms in " rest"
Hello Louis II,Hi Boris, I had the exact same problem.
I found that the arm of roller can move sufficiently to come into contact with the channel and cause a loud metallic rattle on very bumpy roads which I solved with felt pads on the top of the arm.
I also found that the nylon roller rattled in the channel as you described and solved this by cutting some foam packaging material and wedging it in to the end of the channel so that the roller presses into it when the door is closed.
There is a factory fitted pad at the other end of the channel which is what gave me the idea.
Hope it helps. I too was driven to distraction by the rattle. Over winter I had the awning off and spent ages fiddling with catch plates and pretty much every adjustment possible on the door, even to the point of removing the door card and b pillar trim all to no avail before getting to this point.Hello Louis II,
I think this may be the answer. I can't tell you how much this issue has annoyed me. Every damn pot hole and surface imperfection has been amplified in my right ear for the last three years.
Unfortunately, I will be unable to try out your fix until after Easter when my time becomes my own again. Until then I'm owned by our grandchildren. I will let you know if it has worked.
What I can't understand is why some vans are dogged by this rattle issue but most are not. They all have the same awnings, nylon guide wheels, brackets, upper door guide channels and door catch plates. Is it just down to correct adjustment or is there something missing? Should there be a factory fitted felt pad in the upper door runner guide track? If so has mine fallen out?Hope it helps. I too was driven to distraction by the rattle. Over winter I had the awning off and spent ages fiddling with catch plates and pretty much every adjustment possible on the door, even to the point of removing the door card and b pillar trim all to no avail before getting to this point.
Awning is now back on and sounding like pound coins in a baked bean can. Have tried all the standard stuff but coming to the conclusion that the problem with mine is the cables / springs inside the arms so currently contemplating removing them to have a look inside.
I agree the rattles are random and also people have varying degrees of tolerance for the rattles. I hear and am irritated by every small noise. My wife wonders what I am on about.What I can't understand is why some vans are dogged by this rattle issue but most are not. They all have the same awnings, nylon guide wheels, brackets, upper door guide channels and door catch plates. Is it just down to correct adjustment or is there something missing? Should there be a factory fitted felt pad in the upper door runner guide track? If so has mine fallen out?
Did you previously have the lump of stuck on foam?I have recently bought and fitted them and it has stopped the rattling for me .
Dubstep?I never used to have an external rattle on my 2017 Ocean (only the normal stuff when you carry a cutlery drawer in your car)
I have just fitted an awning. Now I have an external rattle. I have found turning the music up has solved the problem.
Funny enough I have exactly the same thing..2 years ago we had our awning replaced because the material came apart.that one never made any noises.We had a new awning fitted and this does rattle. It seems like it’s the whole unit not something inside.. I’ve made sure the two brackets are in the right place.. still the same..Tried tightening it up as much as I dare..still the same..tried rubber under the ends still the same..It is bareable but gets on your nerves on a bumpy road..Is there any other suggestions? Is it just happening to the later model awnings?.I never used to have an external rattle on my 2017 Ocean (only the normal stuff when you carry a cutlery drawer in your car)
Dubstep?
Hi Borris,Hello Louis II,
Something else to check: post #14Hi Borris,
Few years ago now but did you ever get to the bottom of this rattle?!
Thank you I will have a look at report back!Something else to check: post #14
Awning rattle
My second hand 2016 Ocean T6 awning knocks when I drive over bumps and I realise that a rubber bumper is missing ( I can see the outline where it was stuck on the awning housing. Is it possible to purchase a new one as the sponge and duck tape temporary repair doesn't look good.vwcaliforniaclub.com
That’s a useful idea. We don’t have a rattling problem, but I’ve noticed that the sharp upper edge of the wind out section, rubs on the housing where it rests, and in areas it’s biting through to the base metal. I had thought of helicopter tape along this strip.Thanks BJG,
Helicopter tape works To prevent the damage, I did mine from new, now 5 years old and no wear to the casing, I also applied two thin strips to either side where the outer most casing (edge of wind out section ) meets the main fixed housingThat’s a useful idea. We don’t have a rattling problem, but I’ve noticed that the sharp upper edge of the wind out section, rubs on the housing where it rests, and in areas it’s biting through to the base metal. I had thought of helicopter tape along this strip.
There’s always a rattle waiting in the wings (or the doors, windows, bonnet, cupboards … )Well, fixed my rattle somehow, I think anyway. Not sure how. Fitted new spring clips to the awning (replacing rubber pads) fit rubber hose around the roof scissor that was missing, greased witches hats, and silicon sprayed door seal. Seems to have gone but for how long?
On another note about 6 other rattles have caught my attention now but nothing quite as had as the one I've just fixed.
