Hi Loz, sorry to return to this topic but can I ask where you bought your Pro rack from. Having difficulty tracking one down in the midlands area. They talk about T5 version but not T6 (and I don't want to convert a T5 rack. Thanks in advance.
Link to supplier here https://vwcaliforniaclub.com/threads/bike-rack.31002/post-359678Hi Loz, sorry to return to this topic but can I ask where you bought your Pro rack from. Having difficulty tracking one down in the midlands area. They talk about T5 version but not T6 (and I don't want to convert a T5 rack. Thanks in advance.
Hopefully not. Got manual gearbox now so feel a bit more in control.Fab: Don’t bend this one![]()
The rack comes with instructions, four clear vinyl self adhesive strips as paint protectors and two rubber pads for the two top mountings.Looks great JW! Any tips for fitting? Picking mine up tomorrow.
The two rubber pads do not fit the top plastic mouldings. Recommend replace with 1mm sheet rubber (here is a good source: https://www.amazon.co.uk/Rubber-Sheet-300mm-1mm-Thick/dp/B00MTW4VRA/ref=sr_1_6?adgrpid=52744647483&gclid=CjwKCAjwkenqBRBgEiwA-bZVtmCPYgkF1cjy_pngVVSo49WyFEUG9D9Y-8Aj3JFMjFjkNIYCeNvTmRoC7YgQAvD_BwE&hvadid=259069415713&hvdev=c&hvlocphy=1007192&hvnetw=g&hvpos=1t3&hvqmt=e&hvrand=14527207962351674918&hvtargid=aud-612972976282:kwd-295051349206&hydadcr=28151_1724832&keywords=1mm+rubber+sheet&qid=1566214622&s=gateway&sr=8-6 ) and cut to size, or carefully cut off the silly lips on either side of the pads and just use the now flat pads as per the instructions. Be careful not to damage your tailgate hinge paint during installation. The top brackets are tricky to fit - some lifting / thrutching etc will be needed. I suggest you wrap the lower brackets in a soft cloth so that they don't damage your tailgate during top bracket installation. A spare pair of hands was always on hand for me - I suggest you have this facility too!
OK to the bottom brackets. The clear vinyl strips will only provide limited protection for your tailgate paint so go easy if you go this way. If you go the 1mm rubber sheet route for the upper brackets then you will have some sheet left over - use this to wrap your lower brackets to provide a cushion before installing. You will need to be careful to align your lower brackets so they do not foul the light cluster when your tail gate closes. If you have a soft close tailgate be careful not to let this close before you are ready. Take your time. Don't start this job if you are in a hurry. You will regret it!
If the above is not making sense then PM me and I'll give you my phone number if you want to discuss the detail.
All the best.
First post so gentle please!We stock the Fiamma racks and it is also worth looking at the new Menabo rack
VW Rear Mounted Menabo Shadow Bike Carrier
Menabo Shadow rear mounted bike carrier, allows you to carry upto 3 bikes without a towbar or roofbars. Ideal for bikes with wheels up to 4" wide and a diameter up to 29" Suitable beams for frames with profiles up to 70mm in diameter Anti-theft system for both the product…vwcaliforniaclub.com
Always give us a call if you see anything cheaper
On a purely visual inspection it looks like the T6 bike rack sticks out 4 to 5" further than the detachable tow bar.Sorry if this has been asked before...Can anyone tell me how far the OEM T6 bike rack sticks out behind the vehicle when folded and not in use? Is it further than the tow bar?
