Never had a problem in bad weather on C & MH sites when I’ve explained why I’ve angled the van, but always have one vehicle corner to the road to peg line.Tail to wind whenever possible.
Unfortunately because the Caravan and Motorhome Club and the Camping and Caravanning Club both insist (Rigorously) that for insurance/fire risk reasons you nust park face in or face out with one corner next to the white post this does not allow you to "safely" park tail to wind whic might be at an angle across the pitch.
So safety rules sometimes create risk!
the noise and the rocking which improved substantially once we dropped the roof.
I love those two.See below.
I have had my Cali out in 55mph winds recently and all was good. The only advice might be to ensure you are backing the Cali into the wind i.e. pointing the lower edge / rear of Cali into direction of the wind...Hi all
Currently camping at Pulruan Cornwall, and it’s quite windy gusting at 16/23 mph anyone advise upon allowable tolerance for the pop top bellows. As it not mentioned in the manual.
No there isn’t I’m afraid.Is there a recomended maximum wind speed at which you should close the pop up roof ? I realise there are a lot of variables such as wind direction, gusting etc etc but just wondered if there is a general recomended maximum wind speed ? Mine is a T6.1 Ocean. Thanks
I would have thought it would be a closing pressure pushing against the hydraulic rams and since those are locked the roof scissors would be the first thing to bend ?Here’s a question for amateur physicists...
If parked in strong winds, with the pop top up and rear facing into the wind, will the wind be trying to close the roof, or will it be trying to lift the roof?
The effect will be neutral. There will be an initial downward pressure but the wind bouncing off will cause eddies which will give an uplift. Actually, I just made that up. Sorry, no idea.Here’s a question for amateur physicists...
