If he knew what VW charge for them he would be amazed.I've just taken my leisure battery down to my local motorist discount shop to get it checked out, he said it was spot on but it's not a leisure battery, he said it would have leisure wrote on.
Is he right.
here is a pic of the battery. View attachment 51698 View attachment 51699
www.intercel.nl
That's good to hear.it is a leisure battery same as mine
It must be abt a year, we are away nearly every wk end, but it doesn't get use much at home only short shop runs.when was the last time you charged it using the mains?
Apart from the heater stopping, does the fridge continue?That's good to hear.
My problem is after a fifty mile ride &park up for the night with fridge, one light on over the cooker, we put the heater on & it cuts out after abt two to three hours, that's on the lowest setting, plenty of diesel, earth shunt done.
The van is 2007 I don't know if they are the original batteries, I've had it three years.
I'm thinking of just putting them back in & putting a solar panel on the roof.
Anyone got any ideas. Cheers.
Hi T, how on earth did you spot that on the terminal, I tried to zoom in & still could not see it, nice to know the year.Just looked at your first picture: 36 (week) 07 (year). So it might be a good idea to renew the batteries.
Not only is it cheaper than installing a solar panel (if you weren't doing it anyway), but if the batteries degrade further, you will have the risk of damaging the batteries (in worst case explosion and damage to the interior) up to the point of the batteries not working at all anymore, even with the solar panel, leaving you with the only option: changing the batteries after all.
Solar panel is a good idea, but not only for the purpose of keeping a dying battery alive. What happens when you take the night out? No sun = no batteries charging = cutoff of the heater, fridge, lights, ...
Both heat no probs.Apart from the heater stopping, does the fridge continue?
and what about the lights.
Sorry meant to say no probs any where apart from heater.Both heat no probs.
Been done.Earth shunt?
Both been checked.The OP is talking about "the battery" as if there is only one. There are two, one in the boot, the other under the passenger seat. Both would need verifying.
it really needs plugging in once a month as driving will not fully charge it i would say new battery neededIt must be abt a year, we are away nearly every wk end, but it doesn't get use much at home only short shop runs.
Thanks, sounds good advice & now I know the age of them I'm convinced. Change them I will. Should I get exactly the same. Cheers.Damn, my whole story is gone![]()
the tester might give it a good score without being really good.
Had the starter battery of my Golf 4 charged completely once and checked. The test was excellent, but after 2 weeks of cranking up the engine in wintertime, it started failing again.
If I were you, and I am not, so... I would change the 2 leisure batteries, just for my own convenience.
You are still able to put on a solar panel, but not for keeping those dying batteries alive, as that won't help anymore for a long time. They might charge good, but they won't hold their charge anymore, so you will keep having the problems of cutting outs, needing to replace them nonetheless.
