Loz
Coast VW in South Moulton have been a Siekel dealer for years and they fitted mine..
I'm not sure of the connection between Coast and Seikel as no Seikel info on Coastvw.co.uk website (I might be looking on wrong site). On contacting Seikel.de they now direct you to their new "partner for the United Kingdom" Volkstrek 4x4 (not sure how they spell their name). I guess Coast is a dealer/agent and Volks Trek now the official partner as have showroom, demo vehicles and fitting workshop opening at end of month. Only going on what I've been told.Coast VW in South Moulton have been a Siekel dealer for years and they fitted mine..
I feel Seikel is the most sensible choice from what I now know.It seems Seikel would be the easier way of getting the same as you did. What do you think about increased wear and less life from drive shafts? Is that expensive part to replace?
Is next step also larger tires on the rims? Seikel has a kit with 235/65 R17 tires which lifts even more.
Yes, your absolutely correct, and the caster changes I think, so I guess it would be up to the owner to decide which height they do the most miles in and have it Hunter aligned at that setting.Sounds reasonable Loz.
The point I’m making is that tracking alters with ride height and, as far as I can tell, the VB air system doesn’t include a fandango system for correcting the tracking following a ride height change.
I used Pedders ( made in Australia) and still very happy with them. They did lift the rear some 50mm though which made the van too nose down so lifted the front 30mm to compensate.Skewif, I want to raise the rear of my 4 motion, which springs did you end up using? I'm in NZ so a specification of the spring would be even better than a VW part number as 'VW tax' is strong here
Cheers (your setup sounds great!)
These may be of use for front & rear. you can get spacers for the rear only. Various availableSkewif, I want to raise the rear of my 4 motion, which springs did you end up using? I'm in NZ so a specification of the spring would be even better than a VW part number as 'VW tax' is strong here
Why just the rear?Skewif, I want to raise the rear of my 4 motion, which springs did you end up using? I'm in NZ so a specification of the spring would be even better than a VW part number as 'VW tax' is strong here
Unfortunately the authorities here have an aversion to spacers. It would fail its ‘mot’ if fitted.These may be of use for front & rear. you can get spacers for the rear only. Various available
VW T6 T5 Transporter Eibach Lift Kit 35mm springs | eBay
We have worked closely with Eibach UK to develop this 35mm lift kit for the VW T5/T6 which will work with standard or extended dampers on any VW Transporter T5, T5.1 and T6. Compatible with VW Transporter T5, T5.1 and T6 from 2003 – Current Year (T26 – T32 and 4motions).www.ebay.co.uk
VW Transporter T5 T5.1 T6 T6.1 Rear Suspension Lift Spacers, 25mm BLACK, UK Made | eBay
All of our spacers are manufactured in the UK. These lift spacers are machined from 6082T6 grade aluminium sourced from UK suppliers. PCD Parts/Watfields Limited also manufacture custom parts. All of our wheel spacers, adapters and suspension spacers are manufactured in the UK, from material...www.ebay.co.uk
Can I ask which actual products you specified as their website is not at all helpful in detailing the specs of the products! https://www.pedders.com.au/catalogue/springs/volkswagen#I used Pedders ( made in Australia) and still very happy with them. They did lift the rear some 50mm though which made the van too nose down so lifted the front 30mm to compensate.
I think you mentioned Sachs dampers too?
My plan is to start with the rear springs. Evaluate, then progress perhaps with rear dampers and then front bushes, springs and dampers as necessary and the same as you. I’m sure sidepod means well but perhaps we are starting from a different place than he anticipates. Ie, the std 4motion California is not fit for purpose when loaded (and carrying heavy ebikes on an extended tow bar mounted carrier in my case).
Yes thanks, most helpful. I’ve just been on the phone to the NZ disti and ordered the springs. I’ll evaluate first before buying dampers. The van has only done 25k miles. Cheers for help, jamespedders-heavy-duty-coil-spring-7891.html Unless you really want to raise both ends of the van for ground clearance then T32 rear springs and really good HD rear shocks will give you a superior ride and load handling without needing to change anything else. I would change the rear shocks to something decent first because if your van has done a fair few miles or you're real heavy it will transform the handling and ride under load. I have Sachs HD super touring shocks on the front and Pedders HD shocks on the rear. The Pedders are now getting a little soft for my liking so going to try some Koni Active shocks on the rear soon as heard nothing but good reports. Hope that helps
YesAre they the Rival protection plates Skewif?
Yes left the plastic tray on, no need to take off. Compared to what else is available I feel they are good value. They're also really tough, most impressed with what they can endure without deforming. Seikel rock sliders are great too, you really can easily slide over rocks that would cause major damage without them. Together a small price to pay for peace of mind.Thanks. Pretty good value I think at around £1k for the full set. Did you leave the plastic undertray on or take it off?
6mmWhich thickness did you get?
