P
PeterS
What a weird question, takes all types I guess.
It's a brain teaser.What a weird question, takes all types I guess.
Yeah.. also checked my answer this morning and came out at 3.10. Obviously missing a trick...
Four intrepid California owners, one an Ocean, one a Coast, one a 2 seat Beach and one a 3 seat Beach owner, decide to explore a cave. While deep underground there is a flash flood and water levels in the cave rapidly rise trapping the owners on a narrow ledge. Fortunately, one of the owners has brought with him emergency oxygen and two face masks that will connect to the one supply.
Two owners can escape together, and one can then return.
Due to various competency levels escaping from the ledge takes different owners different times.
The Ocean owner would take 30 minutes
The Coast owner would take 35 minutes
The 2 seat Beach owner would take 45 minutes
The 3 seat Beach owner would take 50 minutes
For example, if the Coast and 3 seat Beach owners escaped together, it would take 50 minutes; and then an additional 35 minutes for the Coast owner to return with the cylinder, a total round trip of 1hr 25 minutes.
In hours and minutes, what is the minimum level of oxygen required for all four California owners to escape safely?
On each outbound leg, there are two people using up the Oxygen for the slower of their times, unless the connecting tube is long enough for the faster one to take advantage of his or her greater speed.Go on I'll buy it.
So the answers is 3 hours and 5 minutes. How can that be?
Your question was, "In hours and minutes, what is the minimum level of oxygen required for all four California owners to escape safely?"
Using your example, unless one of them can hold his/her breath for 50 minutes "the minimum level of oxygen required" for the Coast and 3 seat Beach owner to escape together is 100 minutes. Unless I'm wrong, which is highly likely, the minimum time for them all to escape based on everyone breathing would be 5 hours and 20 minutes.
Go on I'll buy it.
In hours and minutes, what is the total of the time wasted by forum members on answering the wrong question?I can see the fundamental flaw in the way I phrased the question. However, the example of the timings I gave for two of the owners escaping, and one returning, should have rectified the flaw.
Should be zero, given that it was a multiple choice.In hours and minutes, what is the total of the time wasted by forum members on answering the wrong question?
But Tom asked about the amount of Oxygen required whereas his, and many other answers were based on time taken, not Oxygen used.Should be zero, given that it was a multiple choice.
True, but apart from his error in the last sentence everything else pointed to the answer needing to be in units of time.But Tom asked about the amount of Oxygen required whereas his, and many other answers were based on time taken, not Oxygen used.
I wonder if anyone did manage to calculate the volume of oxygen required? One for @WelshGas to give a lead on!
Too many variables, depending on individual body weights/size, amount of effort required to swim etc. Anyway I very much doubt if there is a portable cylinder large enough.Must admit, I did think about asking @WelshGas for his input
The question was - "In hours and minutes, what is the minimum level of oxygen required for all four California owners to escape safely?" The answer was indeed requested in units of time.True, but apart from his error in the last sentence everything else pointed to the answer needing to be in units of time.
Well hardly.I can see the fundamental flaw in the way I phrased the question. However, the example of the timings I gave for two of the owners escaping, and one returning, should have rectified the flaw.
So Tom, what’s the solution to the question you thought you were asking?Hint:
Try to find a way to extract the two Beach owners together.
Solution given this afternoon.
Well hardly.
Anyway I've got to get on with with some DIY now before the boss gets back from church.
This could develop into one of those “classic “ threads that might even challenge the all time greats “roof corrosion“ and “Beach vs Ocean”.Perhaps it is best to think of the oxygen tank as a very unsophisticated piece of emergency equipment. When turned on it releases the gas at a constant rate, sufficient for two people but no more.
I don't know how I got to my answer...my maths failed me again.
My method this morning the same....but takes me to 3:10 so hurry up Tom!!!
Coast and Ocean leave 35
Ocean (or Coast) return 30 (35)
2 seat and 3 seat leave 50
Coast (or Ocean) return 35 (30)
Total 185 or 3 hours 5 minutes
The Coast (who’s already escaped) returns to rescue the Ocean.Question. If the Ocean doesn't do the second trip out (with the 2 and 3 seat) how does he return? The 2 or 3 seat would need to return to bring back the space breather
