As a complete novice, would someone be kind enough to explain why you need different tyres for winter ??? Does this really happen, you don’t change tyres on a car depending on the season
The composition of the rubber in summer tires is optimized for summer temperatures, but these tires become hard and inflexible at low winter temperatures, leading to reduced contact patch and poor adhesion. Winter tires are properly flexible at low temperatures, but become soft and excessively pliable at warm temperatures. All season tires try to strike a balance, and while not being the absolute best at anything, can under most circumstances deal with wide temperature swings from summer to winter. That's why we talk about "winter" tires, not "snow" tires. It's primarily about the composition of the rubber in relation to temperature, and then secondly about more or less aggressive tread patterns.Thanks, trouble is in this country we get soggy campsites in summer due to all the bl**dy rain we get....so would need to keep them on all year !!!!
And that is why there are so many problems and accidents at the first sign of frost, ice or snow in the UK. If you want the best traction you should or adopt a halfway house and have All Season tyres . People use their Californias all year round and either change to winter tyres in the winter or have all year round All Season tyres for the above reasons.As a complete novice, would someone be kind enough to explain why you need different tyres for winter ??? Does this really happen, you don’t change tyres on a car depending on the season
But we don’t get frost or snow for more than a day or two per winter in the Britain. So is it worth it? If you live in the Highlands or half way up a mountain or intend to go to the Alps then maybe it is, but otherwise summer tyres would be fine.And that is why there are so many problems and accidents at the first sign of frost, ice or snow in the UK. If you want the best traction you should or adopt a halfway house and have All Season tyres . People use their Californias all year round and either change to winter tyres in the winter or have all year round All Season tyres for the above reasons.
Obviously if your California is in the garage for 6 month of the year and only used in Summer, no need.
But we do get lots of rain, at low temperatures and All Season/Winter tyres do work better in those situations. I just fit All Seasons as I doubt if I will be going to the Alps in the Winter but when its 5c and the roads are like rivers I seem to be able to get around safely unlike some others in 4x4s with summer tyres.But we don’t get frost or snow for more than a day or two per winter in the Britain. So is it worth it? If you live in the Highlands or half way up a mountain or intend to go to the Alps then maybe it is, but otherwise summer tyres would be fine.
The vast majority of vehicles in the U.K. run summer tyres all year round and you don’t see cars flying off the road, skidding and getting into accidents every time it rains. I think the benefits of winter and or all season are very marginal in a country with such a mild climate as the one we live in.But we do get lots of rain, at low temperatures and All Season/Winter tyres do work better in those situations. I just fit All Seasons as I doubt if I will be going to the Alps in the Winter but when its 5c and the roads are like rivers I seem to be able to get around safely unlike some others in 4x4s with summer tyres.
Seen a few around here in ditches.The vast majority of vehicles in the U.K. run summer tyres all year round and you don’t see cars flying off the road, skidding and getting into accidents every time it rains. I think the benefits of winter and or all season are very marginal in a country with such a mild climate as the one we live in.
Decades ago tyres were either normal (all season) or winter category.The technology to make all season tyres (at manageable cost) is relatively new so the market is still new. I heard that Michelin is moving all its production to 'all season' compounds (may or may not be factual).
If we were starting over, most cars in the UK would be running on all season tyres.
I don’t think the millions of £ spent to come up with the new formulations would support that argument.Decades ago tyres were either normal (all season) or winter category.
And if you are running and consuming the winter tyres, at the same time you are NOT consuming the summer tyres. It is not a double expense.My situation is different to the majority as i Iive in Switzerland. There isnt a legal requirement to have winter tyres but plod will do you for not being equipped for the conditions if you have an accident.
Anyway...
The difference on heavy frost days or days around 3 c is substantial. I have 2 sets of wheels so no big deal to swap.
I certainly recommend to have winter tyres or all season with the alpine symbol. End of day it's not that expensive and compared to stoving the van into something and all repairs or write off after its definitely worth it.
Sent from my SM-A505FN using Tapatalk
Exactly!And if you are running and consuming the winter tyres, at the same time you are NOT consuming the summer tyres. It is not a double expense.
Totally confused......I think All Season as I don’t fancy switching tyres twice a year !
