T6 pleaseT5 or T6?
I just hooked the carrier on the door, marked around the attachments where they touched, with a dry board marker. Then removed the carrier and stuck ‘em on. Perfect match.Hi would anyone be able to post a picture of the genuine cycle carrier prtective sticker installations
Thanks for the replyI just hooked the carrier on the door, marked around the attachments where they touched, with a dry board marker. Then removed the carrier and stuck ‘em on. Perfect match.
Thanks much appreciated
ThanksAs above!!!
sit it on ...
make sure alls straight level with the rear swage line and mark it up with a dry marker or pencil.
Remove put protector on and re fit
What’s a dry board marker?Thanks for the reply
Commonly known as a whiteboard marker. Easily wiped after it’s done the job.What’s a dry board marker?
I've made my own and attached then to the rack rather than the California's bodywork. You can buy heavy adhesive tape in sheets on eBay for a lot less money and you don't need to be clear as the vehicle ones areHi would anyone be able to post a picture of the genuine cycle carrier prtective sticker installations
