Loz
Now you are all up to speed on winter air, are you also keeping your Turn signal fluid topped up in these cold conditions?
I’m afraid my signals about topping have never been fluid.Now you are all up to speed on winter air, are you also keeping your Turn signal fluid topped up in these cold conditions?
Bit of a thread resurrection, is it too early to change back to summer air?
Are those the -30mm. Springs ?I usually have the 4 seasons air to match the tyres. Unfortunately, there's been a shortage of the spring element this year due to the lock down.
I thought you could get the refills fairly cheap?Oh, reminds me, Those people asking for recommendation on air pump on the forum need to be told to get the pump with the air season selector function.
Shouldn’t 4m users be doing a diagonal air swap?I'm keeping my winter air for now and waiting for the new normal air to be available.
I'll be swapping the front air for the back air to even out the wear though. 4 motion owners need not bother.
When collected from different altitudes spring air can also be used to alter ride height.I find that Spring air gives the best ride quality
Yes and then there is the choice of high or low pressure air depending on the weather conditions when purchased.Shouldn’t we be considering filtered air this season?
Great Tip there!I keep two old air beds for this purpose, one with summer air and the other with winter air mostly used as part of recycling air removed from tyres during change over process
