Loz
A how-to guide for changing the rear disks and pads. (I originally posted this on the T6F in 2019)
As with any information of this kind please only undertake this job if you have the tools and feel you are capable of doing the job otherwise seek professional advice or take it to a dealer.
Security Choc another wheel, ten Jack-up and remove the wheel you are starting with.
Release the handbrake and then using 2 screwdrivers, lever down the handbrake arm and flip out the end of the handbrake cable.
Remove the calliper screws and discard (New bolts supplied with pads)
Lever off the calliper and rest it on the driveshaft/shock, do not let it dangle on the brake pipe.
Disconnect the wear sensor cable connector. (there is only 1 on the inside pad on the offside wheel) Push the plug up, Pinch as indicated and pull down.
Now remove the old pads and retaining clips and discard. As you can see the rusty disks have destroyed the pads and worn down the sensor.
Using a 21mm socket and a long bar remove the 2 large bolts securing the carrier to the hub.
Using a 10mm spline(double square) bit remove the disk retaining screw.
The old disk can now be removed. It may take some beating with a Brummy screwdriver, use penetrating oil around the hub to help it come free.
We are now ready to fit the new parts.
