Borris
My three year old Beach 150ps manual has just demanded an oil change in ten days time. It has currently got around 29000 miles on the clock and is on the Long Life regime. It had it's previous oil change at around 15000 miles in March 2018. The reason for my thread is to ask:
1. Has anyone else carried out a DIY T6 oil and filter change as well as a pollen filter change?
2. Where is the oil filter located on a T6 150ps manual? I've had a poke around under the bonnet and I can't see anything resembling an oil filter or filter housing.
3. How do you reset the service indicator?
4. Where is the pollen filter located?
Yes, I could and would have just booked it into my dealer to have it done but having just been quoted over £250 for a simple oil and filter change (reduced to £235 after I exclaimed "HOW MUCH!"), I am now questioning why I would want to do that. To have this done would also cost me a day in time as the dealer is a long way from where I live. I can source the long life oil and genuine parts locally at a good discount and do the job in around an hour saving me at least £100 and the best part of a day. I suspect the oil filter is located down the back of the engine and probably accessed after removing the under tray. Can anyone confirm? As for resetting the oil service indicator on the MFD, that's usually done by a sequence of pressing this and that. As an example, on my wifes Skoda Superb you have to have the hazard warning lights on to reset the service indicator! All done to prevent people doing their own servicing no doubt! However as the T6's engine management system constantly monitors the condition of the oil and triggers the oil service due message when the quality deteriorates to a preset level, will the fresh oil automatically delete this message and negate my having to reset anything?
Finally, I have one of those brilliant sucking devices that removes all the oil from the sump via the dipstick tube in minutes without getting under the car. What are your thoughts on using these gadgets? They are useful for a quick oil change but in this case, if I've got to remove the under tray to change the filter then there would be no point in using it as I might as well drop the oil out then.
Any advice would be welcome.
P.s The vehicle is now out of the 3 year manufacturers warrantee period although it does have an extended two years warrantee obtained at time of purchase.
