larrylamb
There are definitely scrotes everywhere that would like to relieve you of your valuables. Although not impervious to crime, campsites are the safest and also other areas with fellow campers. Use common sense with regard to the area you choose and with the Cali locked whilst you sleep it is a more secure vehicle than a motorhome with a caravan style door. Enjoy your travels.pretty bad parents too if their 11/8yr olds are drinking. Having never been robbed in a Motorhome, I’d like to think you’d wake up if someone was to jimmy the lock and walk around the Motorhome..
Just as an aside, what about the Chadwick case where they were given blood tests which highlighted CO poisoning? Or does that come from wine too?
I should put a wee disclaimer here.. I’d rather gassing not be possible and deep sleep be the answer. Either way, the risk of robbery either through sleep/gas is the same. We have a dog so should push would be robbers to alternative easier targets. Having now done a wee bit of research I can see this is a looong going argument... essentially pick a side and hang on tight. Awaiting any info from my mate and family.... in the meantime, To suggest that someone just slept through is absolutely plausible, however to instantly assume that someone’s close friends are insurance fraudsters is f**kin ridiculous, and anyone doing that needs to give their head a shake, clearly some social skill issues.
