What happens is, cars pull out in front of you, therefore slowing you down.
Where on standard cruise you would have enough time to feather the cruise or anticipate a move to the outside lane. This can be adjusted, but i never found it far enough to make a difference.
If you want to plod along, then the system will probably work.
I bet my van, that average speed over 200 miles will be a lot less with ACC compared to standard cruise...
Did you know that if you indicate to change lane after the van has sensed a car in front it will accelerate into the gap automatically? I found this out and it’s quite alarming when not expecting it!
The size of the gap is adjustable in configuration.I have ACC on the Golf R and CC on the California. I find that it leaves too much of a gap cars cut in and you feel like you're always going backwards.
Yes but it still leaves a gap that people cut in onThe size of the gap is adjustable in configuration.
